san shop gumagamit ng bearing puller? yung sa front wheel ko kasi maingay na. yung iba kasing pinagtanongan ko pukpok lang ang ginagawa eh. salamat!
you can have the hub sent to the machine shop for pressing. that's what we do.
hindi ko pala kelangan magpalit pa ng bearings. hehehe...
para kasing sirang bearing yung tunog kapag tumatakbo.
eh nung nagpalit ako ng gulong, nawala!
pinakinggan ko sa lahat ng speeds, 10 -20 -30 - 40 - 60 - 80, wala na
yung "wug-wug-wug" na tunog.
buti na lang.
Hi Colt, yes puede mo din basis yung vibration sound na "wung-wung" when the tire is rolling. Pero sometimes kasi, that kind of sound is also caused by tires. My suggestion is pa pull out mo bearing, then put your finger in the bearing whole then paikutin mo bearing, pag may naramdaman kang paramg may sumasayad or gumagalasgas pag umiikot palitan mo na siya (may tama na bearing), or pag wala naman ipabalik mo bearing then pa re-pack mo yung grasa ng bearing. Another way of checking your bearing is, pa lift mo sasakyan pero dapat yung naka hang yung tires, then hawakan mo top and bottom ng gulong then galawin mo, pag may play yung tires may possibility na din na may tama bearings mo. I hope this could help, it's based on my experience din.![]()
