Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Anyone has and have tried this OBDII Scan Gauge with local released cars?
    How was it? What data can you get? Do you know where we may get this locally?
    Nov 2003
    what will you use it for? on a honda? make sure it comes with the correct socket. pre-vtec3's did not have the regular obdII port and only came with the 3 prong socket.
    you won't be able to adjust anything tho... maybe monitor lang.
    we've got a more complicated version of that in the shop which we use on cars that need resetting.
    Thanks, speedyfix. Was planning one lang sana for the Gen2 Rav. Check it naman to have an OBDII port already. Yes, wanted it for monitoring lang sana. Do you know a place that may be selling this, or a similar gadget?
    Inquire lang din on the version you have on your shop. What services can your shop do to a car with it? Thanks.
    Nov 2003
    you might be better off ordering it in the US. alam ko the most basic obdII readers retail for about $4-600. the one in the shop is a little less than $4,000.
    you can check the site:
    http://launch-techs.com
    this is the unit we have:
    http://www.launch-techs.com/x431/
    andyan narin features nya. iba iba depending on the car tho. sa mga benz and bmw super dami pwede gawin. from the interior and radio of the cars to checking and sending signals to specific sensors to check if they are working correctly.
    on the xtrail you can advance timing which make it even more fun to drive.
    on a honda all you can do is reset the box and monitor different things.
    pretty complicated to explain exactly what it can do pero if you're interested you can read the site.
    interesting. sarap ikabit sa outlander :D
    Thanks, speedyfix. Am hoping it is or will be sold locally somewhere.
    OT. Will send you na lang din a PM re: services possible in your shop. Thanks.
    Nov 2003
    replied na
    Apr 2006
    those things sell like hot cakes. ubos na lahat ng kanilang first production run. next production will be may06. its a nice gadget to have so you can monitor a lot of things: revs, fuel consumption, outside temp, etc. as long as you have an obd2-compliant socket, which all cars post-1996 should have.
    Apr 2006
    dbl post
    Quote Originally Posted by KoKoNAT
    Thanks, KoKoNAT. Do you know a place that sells, or was selling one locally before naubos yung first production? Either they still have unsold old stock or will have the new stock soon.
    Nov 2003
    unfortunately, the philippines did not stick to the worldwide obd implementation. 1996-2000 hondas do not have obd ports. other cars naman have their own things going on where you need vehicle specific sockets to read their data.
    i think you're safer betting on obd ports on cars 2001 and up na.
    on nissans tho, may special sockets sila and depending on whether the car has a can-bus or not you may not be able to read it with the obd reader.
    Apr 2008
    up ko lang to, dont want to create another thread with the same topic
    using this one as well but not the jurassic looking one as posted, im using the lastes version with xgauge.. so far this is my favorite mod on my vehicle..
    anyone with good xgauge command? pa share naman dito. thanks!
    Quote Originally Posted by Autobeat View Post
    Haha..I ddnt know the predecessor looks like 1960s transistor radio.
    Here's the latest SG2 im using
    Quote Originally Posted by Da_Hon View Post
    Everything you want to know about SG2 from Ample Outdoors - http://www.ample-outdoors.com.au/store/faq.php?cID=1
    Xgauge commands - http://www.scangauge.com.au/support/xgauge.shtml
    OBD2 codes and more - http://www.obdii.com/obdii.html
    Apr 2008
    thanks for sharing!
    if got mine locally. found some commands already, i tried the Horsepower and fuel percentage reading... the best!!!
    eto pa...
    http://www.scangauge.ph
    ^Wow Scanguage now in the Phils just this January, and at p7.25k thats a good deal.. What version did u got?
    Mine is
    Its a bugger for the initial calibration.. I tried several drive and fillup before getting the accurate correction factor.. And it reads LHK not KPL.
    But overall, one of my best mod.:cool:
    Apr 2008
    i got the 3.15version..
    sana they would release xgauge that will compute kpl not in lhk na.. whats the difference between the 3.17 and 3.15? scangauge.com and scangauge.ph offers 3.15 lang, sa au. 3.17 na.
    try using the fuel level percentage para wala na calibration
    As per Phils site, they are offering 3.17? or maybe new release ito?
    3.15 to 3.17 some minor bug fix lang. Here are the firmware history:
    source Ample Outdoors
    Versions 3.0 to 3.14 - Base ScanGauge features were in place, minor technical changes were made to prepare for X-Gauge release.
    Version 3.15 - (2007) X-Gauge functionality added.
    Version 3.16 - (~2009) AVG and TFC X-Gauges included in firmware.
    Version 3.17 - (2009) Minor bugfix release for the Gallons/Litres to Empty X-Gauge, sometimes the word Gallons or Litres would flash across the Gauge screen on some vehicles.
    Version 3.17mb - (05/2010) Minor bugfix release for some vehicles that use the KWPF protocol (particularly vehicles that used a Mercedes Benz engine) Fixes a timing issue that prevented the SGII connecting to some KWPF vehicles.
    Version 4.02 - (04/2011) Major release. Changes to menu system and setup options. Turbo Boost gauge and Horsepower gauge added as standard gauges. Performance Monitor added - record, save and playback up to 8 performance runs. Revisions to Trouble Code clearing protocols. Fuel consumption can now be displayed in kilometres per litre or Litres per 100 km. Alternate method for clearing DTCs. Horsepower gauge adjustment. Changes to the on screen Menu structure
    Im still figuring out how to re-flash to 4.02. Built in na ang boost gauge at may support na sa Kilometers per Litre unlike dati LHK lang.
    They have the cute version scanguage-e. I dont like the size, maliit na at 2 gauges lang ang display.
    maganda nga itong scanguage. saw this before in yarisworld.
    will this work kaya on Pajero fieldmaster?
    from ScanGaugeII - Compatible Vehicle List for Australia
    [SIZE=2]Mitsubishi ScanGaugeII Compatibility[/SIZE]
    [SIZE=2]/ Challenger 2.5L Diesel (2009 - on)[/SIZE]
    [SIZE=2]x Challenger V6 (2003 - 2005)[/SIZE]
    [SIZE=2]/ Colt (2005)[/SIZE]
    [SIZE=2]x Lancer (up to and including 2007)[/SIZE]
    [SIZE=2]/ Lancer VR-X (2005)[/SIZE]
    [SIZE=2]/ Lancer VR-X 2.4L (2010)[/SIZE]
    [SIZE=2]/ Outlander Petrol 2.4L (2006 - on)[/SIZE]
    [SIZE=2]/ Pajero Diesel NS / NT (2007 - on)[/SIZE]
    [SIZE=2]x Pajero Diesel NM / NP (all NON common rail models)[/SIZE]
    [SIZE=2]/ Pajero V6 3.8L (2004 - on)[/SIZE]
    [SIZE=2]/ Pajero V6 3.5L (2004)[/SIZE]
    [SIZE=2]x Triton MK Diesel (all models)[/SIZE]
    [SIZE=2]/ Triton ML CRD Diesel (2007 - on)[/SIZE]
    [SIZE=2]/ Triton ML V6 (2007 - on)[/SIZE]
    [SIZE=2]/ Triton MN 2.5 CRD Diesel (2009 - on)[/SIZE]
    AFAIK Old school diesels and carb engines no support.
    Compatible with most electronic fuel injected na may ECU including CRD engines
    Check na lang sa site, baka mag mukha akong salesman ng SG..
    more FAQ's:
    AU - Ample Outdoors
    global - ScanGaugeII - Frequently Asked Questions
    Ph - ScanGaugeII - Frequently Asked Questions
    Sep 2010
    They have the cute version scanguage-e. I dont like the size, maliit na at 2 gauges lang ang display.:
    sir any news on flashing to new firmware?
    tnx
OBDII Scan Gauge - Anyone tried this?
