Results 21 to 40 of 44
    #21
    Bagsak ang quality ng fuel satin di yung auto!!
    #22
    di naman siguro sa fuel, paano naman nasabing marumi ang fuel natin compare sa ibang bansa, dapat lahat tayo bagsak sa emission test kung ganoon, ako bumaksak na rin minsan sa emission test pero ngayon hindi na ang ginagawa ko lang bago pa emission test , tuneup change spark plug and adjustment ng valve clearance, change oil, change air filter, ayon parati nang pasado.
    Oct 2004
    #23
    Baka kailangan lang ng tune up kaya bagsak sa CO... baa restricted/clogged na yung air filter, or fould na yung spark plugs.... :?
    I had an engine swap last march, yung spark plugs ang oil ko yun pa rin mula nung pinalatan during the engine swap, when I had my emissions testing last June, CO=0.01% (limit 4.5%), HC=4ppm (limit 800ppm)....
    check this out... (medyo malaki po yung image eh)...
    CLICK ME!!!
    #24
    guys sa me problema sa usok or bagsak sa emission test (gas or diesel) try our decarbonization (carbon cleaning).
    it will remove all the carbon deposit from intake valve, combustion chamber, sparkplug and catalytic converter. the procedure will just take 30min - one hour.
    90% of black smoke will be removed, original horsepower will be recovered, fuel consumption will decreased.
    as low as Php1,750.00.
    for inquiries please email alsosing*yahoo.com or text 0917-8555760
    Jul 2006
    #25
    pwede ba bumagsak sa emission test
    kahit yung car mo ala naman nilalabas na usok?
    Oct 2004
    #26
    Quote Originally Posted by sirmykel View Post
    pwedeng pwede... wala naman po kasi sa visible na usok yun... depende sa gaseous composition yun ng emission....
    #27
    sa san juan lto, walang bagsak.
    basta dun ka sa likod ng lto magpa-emission test.
    sila may-ari rin ng testing center.
    Oct 2004
    #28
    Quote Originally Posted by zero View Post
    LTO owned? Puro private po ang mga emissions testing centers....
    Aug 2006
    #29
    All you need is Italian tuneup.
    Aug 2005
    #30
    carb cleaner and tuned up lng yan...
    Aug 2005
    #31
    yong 200 petot na palusot na alala ko tuloy first time ko pa nag pa emission test at nag ka auto kc student din ako.. nag tip din ako non.. hehehe..
    Aug 2006
    #32
    Try mo sa BOHER basta sa kanila ka kukuha ng TPL.
    Jul 2005
    #33
    btw, although wala akong problema dyan curious lang ako...ano bang standard ang emission sinusunod ng pinas? meron ba tayong sariling pagaaral dyan?
    ano ang mga batayan ng LTO...europe has it own standard...states in the US have their own...california being i guess the toughest.
    Oct 2004
    #34
    Quote Originally Posted by nerbyoso View Post
    namemeasure lang po is:
    For gasoline engines (spark ignition engines):
    Carbon Monoxide (CO) percentage and HydroCarbon (HC) content...
    1st registration of vehicle: (maximum readings)
    < Jan 1997 = 4.5% CO; 800ppm HC
    >= Jan 1997 < Jan 2003 = 3.5% CO; 600ppm HC
    For Diesel Engines (compression ignition engines):
    Opacimeter result limit (max) 2.5K
    Sana namemesure din pati NOx, which is as actually as harmfull as CO and HC....
    Jan 2009
    #36
    ^ Yan malamang yung mga "no-show" na nagpapa-rehistro through a fixer without the vehicle.
    Jan 2008
    #37
    Kaya kalokohan yan pag nasa private eh walang milagro.. basta pinoy gagawa ng lusot.. dati yung lto susuhulan mo ngayon yung emission testing center din
    #38
    Wonder why nobody's talking about this stealth development....[emoji848]
    Sep 2016
    #39
    Panalo yung babaeng pinatong lang sa mga kotse eh. Taba ng utak nung nakaisip.
    #40
    Hindi ko halata na edited
bagsak sa emission test...
