Originally Posted by
Jayo
No gaskets were replaced, no sealant was used. Both pan and screen gaskets were reused for the second time. Also, silicon sealant is not advised since it may clog the screen if used on the pan gasket or may find its way to the pump and valves if used on the screen gasket. All bolts were tightened using a nut driver, 10mm pan bolts and 8mm screen bolts.
