Results 1 to 11 of 11
    any ideas mga bro kung anu talaga stock battery size ng accord 96? last january kasi ngpalit ako ng batt..1sn na motolite enduro..sinunod ko yung battery size na dating nakalagay(1sn din)..kahapon biglang na totaly drain yung batts ko..pati alarm or busina ayaw..so pinacharge ko knina sabi underrated daw yung 1sn para sa accord since 2.0 daw yun sabi nung batt shop..pansin ko maluwang din yung space na lalagyan ng batts sa car..any ideas mga sir? TIA
    5th gen (94-97) 2SM Bro.
    Sep 2004
    2SM nga ang stock size ng battery ng 5th Gen Accord.
    But immaterial naman kesyo 1SM or 2SM, kasi the battery is mainly used to crank up the engine. Pag umaandar na ang makina, the alternator takes care of the electrical requirements ng car. Mas marami din ang plates ng 2SM due to its slightly bigger size.
    Since na-drain ang battery less than 6 mos. after you bought it, cahnces are either defective yun, or may tama na ang alternator mo, kaya hindi sya kumakarga.
    ah ok sir thanks po sa info..
    last question po..assuming yung batt nga ang sira..maka claim pa rin kaya ako ng warranty sa batts? since 6 months ko plang naman nagamit yung battery..TIA
    Sep 2004
    Pag napatunayan naman ng battery shop na pinagbilhan mo na ok ang charging system (alternator, voltage regulator, etc.) ng sasakyan mo, at talagang yung battery ang may diperensya, you can claim the warranty.
    ...or may ground na component ka sa electricals.
    Quote Originally Posted by afrasay View Post
    yup, ganyan din nangyari sa kotse ni mrs, akala namin battery un pala grounded un brake lights, nagpalit pa kami ng battery tapos na-drain din un bagong palit.
    Quote Originally Posted by Galactus View Post
    Maaaring ma-prove mo ito,- pero medyo inconvenient para sa iyo. Tsaka, gagawa pa sila ng physical/chemical analysis sa baterya (yata?), so may take some time.....
    3101:transform:
    got my recharged battery from the batts shop yesterday and try ko kinabit knina..so far ok naman..1 click start..tried removing the positive terminal and hindi naman namatay yung makina..so i conclude na hindi alternator problem..wait ko till tommorow kung hindi sya mag diskarga..
    Ano ba ang battery lifespan ng 1SM & 2SM, assuming the same usage..ano magiging epekto kung 1sn gamit ko imbes na 2sm?..TIA
    Nov 2003
    better to use the correct size para wala ka na iisipin.
    sayang naman kung papalitan agad..gamitin ko nalang muna..hehe..
any idea?
