Results 1 to 10 of 12
- Jul 2009
- 18
August 18th, 2009 05:14 PM #11991 nissan maxima
all power
2.0
anu po recommended na gas para dito? sa shell caltex or petron
need sum advice mga guru..
and oil
anu po dapat ko ilagay yung maganda performance and makakatipid
salamat
August 18th, 2009 06:21 PM #2
any fuel available in the market will do. hwag lang regular, lpg, diesel o kerosene. any gas station will do.
as for oils, use mineral. just observe the regular change oil intervals at 5000 kms. you can use any brand of oil too. as long as it is mineral. palitan mo din yung oil filter mo every oil change.
August 18th, 2009 07:59 PM #3
efi engine na ba auto mo? kung carbed pa, better use non-e10 gasoline for the mean time till market is not 100% e10 gas,.
oil? please prefer to your manual for the viscosity of the oil, better of with thicker oils since your engine is almost 2decades old, 10w40? or 20w50?
- Jul 2009
- 18
August 19th, 2009 10:24 AM #4thanks sa mga replies po...
paano ko po malalaman if efi ang fuel system ko or carbed?
1 thing i noticed, para mag pump yung gas ko dapat maayos yung fuse ko, kasi nangyari na po sa akin na busted ung isang fuse ko and sabi ng mechanic yun daw po ang nag aakyat ng gas sa auto ko...
red fuse 10amp po ata ung nilagay na bago then ayun 1 click nag start na auto ko
any ideas mga guru
salamat po
August 19th, 2009 12:21 PM #5
lam ko both carbed and efi engines have fuel pumps,. may ground siguro sa wirings mo bro, kaya nasisira fuse mo, pahanap mo yung grounded wires/ or faulty wires sa TAONG MAY ALAM.
if a carburator body assy is located sa ilalim ng air filter and have a distributor cap connected sa high tension wires mo papunta on top of the engine head where the spark plugs are plugged in, and it must be a carb engine, please do correct me,.
- Jul 2009
- 18
August 19th, 2009 12:28 PM #6ok...got the big picture na
its a carb engine po aj.
so bawal sa akin ang with e10 gas??? ganun po ba yun?
yung about sa ground wires/connections... ok na po ako dun sa part na yun...so far di na nasisiraan ng fuse...
- Jul 2009
- 18
August 19th, 2009 12:30 PM #7ok...got the big picture na
- Jul 2009
- 18
August 19th, 2009 12:36 PM #8ok...got the big picture na
August 19th, 2009 01:04 PM #9
di naman sa bawal sir, its just e10 is not made or designed for carbed engines, try to search for e10 related topics here in tsikot.
August 19th, 2009 01:10 PM #10
Use Petron XCS with 95 octane ,or Caltex Gold for better combustion . If you want fuel economy .
1. Proper maintainace like Tune up, regular change oil,filter,spark plug .check timing and others .
2. Driving Habit .
3. Weight reduction . Removed unnecessary material in your trunk to make the car more lighter you know how heavy the body Maxima.
4. Change reccommended transmission gear oil.
