any fuel available in the market will do. hwag lang regular, lpg, diesel o kerosene. any gas station will do.
as for oils, use mineral. just observe the regular change oil intervals at 5000 kms. you can use any brand of oil too. as long as it is mineral. palitan mo din yung oil filter mo every oil change.
paano ko po malalaman if efi ang fuel system ko or carbed?
1 thing i noticed, para mag pump yung gas ko dapat maayos yung fuse ko, kasi nangyari na po sa akin na busted ung isang fuse ko and sabi ng mechanic yun daw po ang nag aakyat ng gas sa auto ko...
red fuse 10amp po ata ung nilagay na bago then ayun 1 click nag start na auto ko
lam ko both carbed and efi engines have fuel pumps,. may ground siguro sa wirings mo bro, kaya nasisira fuse mo, pahanap mo yung grounded wires/ or faulty wires sa TAONG MAY ALAM.
if a carburator body assy is located sa ilalim ng air filter and have a distributor cap connected sa high tension wires mo papunta on top of the engine head where the spark plugs are plugged in, and it must be a carb engine, please do correct me,.
Use Petron XCS with 95 octane ,or Caltex Gold for better combustion . If you want fuel economy .
1. Proper maintainace like Tune up, regular change oil,filter,spark plug .check timing and others .
2. Driving Habit .
3. Weight reduction . Removed unnecessary material in your trunk to make the car more lighter you know how heavy the body Maxima.
4. Change reccommended transmission gear oil.
