Results 1 to 12 of 12
    1991 nissan maxima
    all power
    2.0
    anu po recommended na gas para dito? sa shell caltex or petron
    need sum advice mga guru..
    and oil
    anu po dapat ko ilagay yung maganda performance and makakatipid
    salamat
    any fuel available in the market will do. hwag lang regular, lpg, diesel o kerosene. any gas station will do.
    as for oils, use mineral. just observe the regular change oil intervals at 5000 kms. you can use any brand of oil too. as long as it is mineral. palitan mo din yung oil filter mo every oil change.
    efi engine na ba auto mo? kung carbed pa, better use non-e10 gasoline for the mean time till market is not 100% e10 gas,.
    oil? please prefer to your manual for the viscosity of the oil, better of with thicker oils since your engine is almost 2decades old, 10w40? or 20w50?
    thanks sa mga replies po...
    paano ko po malalaman if efi ang fuel system ko or carbed?
    1 thing i noticed, para mag pump yung gas ko dapat maayos yung fuse ko, kasi nangyari na po sa akin na busted ung isang fuse ko and sabi ng mechanic yun daw po ang nag aakyat ng gas sa auto ko...
    red fuse 10amp po ata ung nilagay na bago then ayun 1 click nag start na auto ko
    any ideas mga guru
    salamat po
    lam ko both carbed and efi engines have fuel pumps,. may ground siguro sa wirings mo bro, kaya nasisira fuse mo, pahanap mo yung grounded wires/ or faulty wires sa TAONG MAY ALAM.
    if a carburator body assy is located sa ilalim ng air filter and have a distributor cap connected sa high tension wires mo papunta on top of the engine head where the spark plugs are plugged in, and it must be a carb engine, please do correct me,.
    ok...got the big picture na
    its a carb engine po aj.
    so bawal sa akin ang with e10 gas??? ganun po ba yun?
    yung about sa ground wires/connections... ok na po ako dun sa part na yun...so far di na nasisiraan ng fuse...
Anu po recommended para sa auto ko...
