Results 21 to 29 of 29
July 22nd, 2003 10:53 PM #21Originally posted by M54 Powered
he means upgraded/stiffer sway bars...lowers body roll even more so than the stock ones....btw, may typo sa earlier post ko - i meant to say you should lubricate the endlinks, not bushings.Last edited by FLiPMaRC; July 22nd, 2003 at 10:57 PM.
July 23rd, 2003 12:50 AM #22Originally posted by geraldmartin
so d ko na kailangan palitan front? lagay na lang ako sa rear?
at kung gusto mo talagang palitan ang front, make sure na stiffer nga ang sa likod. (i.e. 20mm front and 22mm rear)
FLiPMaRC, as I've said before, nilagyan ko ng teflon tape around the swaybar where the heavyduty mount is. Lubricate everything where the polyurethane bushing is touching the metal. Polyurethane Bushings are stiffer than the conventional one, EXPECT it to make some noise.
Squeaky noise = STIFF (and you know its working fine)
Clunky noise = re-torque all bolts :lol:
M54 said "lubricate the endlinks," the after market endlinks comes with a polyurethane bushing.
To make everything clear, look at the installed pic and the WRX OEM vs. Whiteline Stuff.
notice the teflon tape around the Adjustable (20-24) swaybar to further reduce squeaking. and also pictured is the installed endlink, the circle where you would grease it before installing.
OEM vs Whiteline Flat-Out Aussie Made
Circled BLUE is an endlink with Polyurethane bushings (lubricate where the bolt goes) and the Circled RED is the OEM endlink with rubber bushings.
July 23rd, 2003 03:51 AM #23
:cool: Thanks ... I greased the bish out of the bushings but didn't put teflon tape on the bar. Does it make a difference? My bar uses the OEM endlinks, that's why I didn't grease it. Do I still need to?
July 23rd, 2003 05:00 AM #24
OEM endlinks doesnt need to be greased because the squeak is coming from the swaybar mount bushing rubbing the metal. But if you have some spare grease, you can put some on the OEM endlink. But I just dont see the need tho'
July 23rd, 2003 10:08 AM #25
geraldmartin, kung di ako nagkakamali si sir fr3d3rick of HCP(poster din siya rito) eh nagpalagay ng anti-sway bar sa kanyang EK('96 EK yang sa iyo di ba? )...pm mo na lang siya para malaman mo kung saan siya nakabili...
bukod sa anti-sway bars pwede mo pa dagdagan ng rear tower bar at rear lower tie bar tulad nito:
rear lower tie bar
July 23rd, 2003 11:28 AM #26
Parang sa MARC Caltex ang kuha na iyan ha.
July 23rd, 2003 10:31 PM #27Originally posted by Karding
July 24th, 2003 12:21 AM #28
[QUOTE]Originally posted by FLiPMaRC
hahaha * FliPMaRC, grease doesnt last long. Teflon Tape, I believe, doesnt last long either. So, using them both will make the lifespan of being squeakless :lol:
geraldmartin, okay nga din yung lower tie-bar or lagyan mo ng rear upper :p
July 25th, 2003 05:18 PM #29
geraldmartin ito may nagbebenta ng anti-sway bar for EK sa HCP
http://www.hondaclub.com.ph/forum/in...ay;threadid=96
personally, i'd think thrice, before buying that toyota brand new rack and pinion, to fix my 2003...
rack and pinion repair
