Originally posted by geraldmartin
so d ko na kailangan palitan front? lagay na lang ako sa rear?
yes.
at kung gusto mo talagang palitan ang front, make sure na stiffer nga ang sa likod. (i.e. 20mm front and 22mm rear)
FLiPMaRC, as I've said before, nilagyan ko ng teflon tape around the swaybar where the heavyduty mount is. Lubricate everything where the polyurethane bushing is touching the metal. Polyurethane Bushings are stiffer than the conventional one, EXPECT it to make some noise.
Squeaky noise = STIFF (and you know its working fine)
Clunky noise = re-torque all bolts :lol:
M54 said "lubricate the endlinks," the after market endlinks comes with a polyurethane bushing.
To make everything clear, look at the installed pic and the WRX OEM vs. Whiteline Stuff.
notice the teflon tape around the Adjustable (20-24) swaybar to further reduce squeaking. and also pictured is the installed endlink, the circle where you would grease it before installing.
OEM vs Whiteline Flat-Out Aussie Made
Circled BLUE is an endlink with Polyurethane bushings (lubricate where the bolt goes) and the Circled RED is the OEM endlink with rubber bushings.
