Results 1 to 10 of 17
- Oct 2003
- 23
December 5th, 2003 11:28 AM #1kung ang sa gas engine ay tune - up....ano naman po ang tawag pag diesel engine?sensiya na po medyo ignorante pa ko sa mga ganitong bagay ...nag-aaral pa lang ....sana maiintindinhan niyo....salamat.
- 48
December 5th, 2003 02:16 PM #3
Sa pagkakaalam ko tune-up din. Glow plugs are some of the parts that occassionally needs attention. Basically, engine components of gas-fed and diesel units are the same. Except for the main engine, ofcourse. :D
What systems/parts are checked during a tune-up?
-Starting system
-Fuel system
-Charging system
-Exhaust system
-Ignition system
-Engine block
Do-It-Yourself Vehicle Maintenance Checks:
-Inspect V-belts monthly. Replace worn glazed or torn belt.
-Check engine oil every fortnight. Remove dipstick, wipe it clean, insert it and remove it again. If oil level is low, add oil.
-Check radiator water/coolant level weekly. Do not remove radiator pressure cap when engine is hot.
-Check brake fluid reservoir. If brake fluid is below minimum mark, add. Do not open cap unless refilling fluids only. Water may cause mixing and premature brake operation.
-Keep windshield reservoir full and keep the wiper blades clean. If wiper blades are worn or brittle, replace them.
To be continued...
December 5th, 2003 02:19 PM #4
Continuation...
-Look for signs of oil seepage on shock absorbers. Test shock action by bouncing car up and down. The car, should stop bouncing when you step back.
-Replace worn or leaking shocks Repair shocks in pairs i.e. both front shocks or both rear shocks or all four.
-Ensure all lights are clean and working including brake and reverse lights, turn signals and emergency flashers.
-Check battery monthly in cold weather, weekly in hot weather and daily on long trips. Make sure cables are attached securely and free of corrosion Check battery fluid level, if need add fluid, but in most cases, new batteries come out as Maintenance Free.
-Check for loose or broken exhaust clamps and supports. Check for holes in muffler or pipes. Repair or replace rusted or damaged parts.
December 5th, 2003 02:28 PM #5
Sheeesssh! I overlooked on one of the pages I was reading.
Click here! To see Diesel Engine Diagnostics. :D
- Oct 2003
- 23
- Oct 2003
- 23
December 5th, 2003 08:01 PM #8pwede po bang pahabol ng tanong? kahit sino po pwedeng sumagot....yung adventure namin magiisang taon na po...use it as shuttle service...di na namin na pa PMS kasi alo pong budget...masyado pong mabigat sa bulsa....nasa 42kms na po ang milage....pero regular po ang palit ko ng langis every 5t kms...ano po ba ang dapat kong icheck pa aside from regular change oil?yung bang ginagawa sa PMS meron bang alternatibong auto service center na mas mura ang singil compared sa casa? any recommendation?salamat po uli....
December 5th, 2003 10:35 PM #9
Gas station service bays usually do some maintenance steps that is definitely cheaper than casa. Just follow what is indicated in your owner's manual when to change differential and transmission oils, change water/coolant system, and other quirks. :D
- 10,620
***y welds! Apparently the subcon that makes the part replaced a worn welding tip but did not...
Chery returns to PH
