Continuation...
-Look for signs of oil seepage on shock absorbers. Test shock action by bouncing car up and down. The car, should stop bouncing when you step back.
-Replace worn or leaking shocks Repair shocks in pairs i.e. both front shocks or both rear shocks or all four.
-Ensure all lights are clean and working including brake and reverse lights, turn signals and emergency flashers.
-Check battery monthly in cold weather, weekly in hot weather and daily on long trips. Make sure cables are attached securely and free of corrosion Check battery fluid level, if need add fluid, but in most cases, new batteries come out as Maintenance Free.
-Check for loose or broken exhaust clamps and supports. Check for holes in muffler or pipes. Repair or replace rusted or damaged parts.
