Results 1 to 10 of 21
- Jan 2020
- 26
January 16th, 2020 04:15 PM #1Hello sirs! So i just changed my tires to used tires. Note that this tires are mine and bought it new pero ginamit ko lang cguro mga 6 mos. Naka tambak lang sa garage. Then when my stock tires worn out, ginamit ko ulit pero yun nga mga sirs, may tunog na parang helicopter pag nasa 60kph or mga 80-90kph. Haha! Nung naka stock tires ako mejo may tunog rin pero sakin okay lang kac bearable naman. Pero yung nakakabit ngaun, nakakairita talaga. So i have done a lot of googling, watching different videos on youtube and I still donÂ’t think what could be the cause of the noise. I suspect four issues though. Whether itÂ’s about cupped tires, imbalanced tires, needs wheel alignment or wheel bearings. What do you think i should do mga sirs? Should i buy new set of tires?
- May 2006
- 1,668
January 16th, 2020 04:26 PM #3
January 16th, 2020 04:53 PM #4
yes... balancing should help... makikita din nung shop kung may issue yung rims (since you mentioned na maingay noon sa lumang tires)
- Jan 2020
- 26
January 16th, 2020 05:46 PM #5
- Jan 2020
- 26
January 16th, 2020 05:49 PM #6Hi sir, actually different mags din. Yung stock ko is 16s tapos ang nakalagay ngaun na maingay is 17s. So you think sir no need to buy new tires? Kelangan ko lang pa balance para mawala yung tunog? Yun din kac plano ko. Mahal kac tires tsaka sayang to kung di ko gagamitin. It looks new since 6 mos lang nagamit.
- 54,207
January 16th, 2020 05:58 PM #7my wild guess is, either "cupped tires" or "tires out of round".
the unique tread wear pattern may be visible in cupped tires.
for tires out of round, it may be more difficult. an old timer advised me, "remove the wheel, over-inflate the tire a bit, and roll it on a flat, concrete surface. it it does not roll straight, it is probably out of round.
alas, the only solution for out of round (oblong), is replacement.
good luck, po.Last edited by dr. d; January 16th, 2020 at 06:09 PM.
January 16th, 2020 06:07 PM #8
- Jan 2020
- 26
January 16th, 2020 06:08 PM #9
- Jan 2020
- 26
January 16th, 2020 06:15 PM #10
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
