Results 11 to 15 of 15
June 8th, 2007 11:53 PM #11
June 9th, 2007 03:15 AM #12
guys can you give us a list of maintenance specially in a/t cars... like checking of fluids etc...thanks
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 10th, 2007 01:14 PM #13mostly cars will require fluid replacemnt every 40k kms. except for oil...
June 15th, 2007 09:41 PM #14
sa atf sir i think kelangan nyo sundin yung requirement ng sasakyan nyo, kasi me tagas power steering system ko so madalas ako magkarga ng atf, marami na ko natry na brand at klase, requirement ng auto ay dexron 2 atf, kaso kung minsan kung ano meron sa auto supply yun na nailalagay, at iba iba ang effect, meron ibang viscosity, density, et. etc.. napansin ko minsan malakas ang tagas, minsan mahina, minsan maingay yung pump, minsan tahimik, depende sa fluid na nilagay ko, kaya nagstick na ko sa fluid na medyo hiyang sa auto, yung dexron 2..
- Nov 2003
- 3,849
June 16th, 2007 09:36 AM #15check mo rin. i.e. pag dex 2 requirement, dex 3 will do since it is backward compatible.
high idle RPM at engine start
