Results 1 to 10 of 60
Unregistered user
- Jun 2003
- 1,121
July 7th, 2003 10:30 PM #1Hello diesel peeps,
Anyone here knows where to get airhorns, ones that are heavy duty and with compressors.
Any idea how much it costs? :beard:
July 8th, 2003 09:00 AM #2
Truck parts supply along Rizal Ave. or A. Bonifacio Ave. will surely have this in stock. What kind of vehicle will this be attached to? Some mechanics modify the alternator vaccum assembly for air supply instead of addtional load from a compressor unit. Ordinary plastic pairs are sold for a couple of thousand pesos. The stainless long air horn is around 3-5K. Some compressors are sold separetely ranging from 800-3K.
I have tried those cheapo air horns before, it comes with its own small compressor. Not much of help came when every electrical surge from starting an engine. The compressor usually got stuck and won't blow air. I think I still have that set somewhere in our garage.
HTH
Unregistered user
- Jun 2003
- 1,121
July 8th, 2003 09:16 PM #3thanks
ill try to check it out
planning to put it in a 91 model pajero. will it fit inside the engine bay?
July 10th, 2003 11:57 PM #4
ung bagong model ng stebel na available sa shop namin..
NAUTILIUS ang name...same tone as airhorns...IN A SMALL PACKAGE!!!
super lakas......i swear..kung hindi ka malakasan..libre kita ng coke....herhehrehr
- Feb 2003
- 65
Unregistered user
- Jun 2003
- 1,121
July 11th, 2003 01:04 AM #6Glenn
mas malakas ba sya sa bosch europa?
yun kasi currently gamit ko...
mejo marami kasi gagawin pag air horns based on research i did.
im planning to get another pair of europas na lang, meron din ba kayo nun?
will the nautilus sound better? nver heard of it pa... but stebel is good got stebel fanfares on our revo
Unregistered user
- Jun 2003
- 1,121
July 11th, 2003 08:36 AM #8
Sheep::: The plastics type will definitely fit under your hood, but I doubt if the long stainless ones will. Dami ko nakikita mounted above the hood like on the jeepneys. Imo, go for the Nautilus, you'll end up with a budget wise option and less headache.
GlennSter::: Parating ka ulit ng horns, naunahan ako ni Rod & Bubbles. :D
Unregistered user
- Jun 2003
- 1,121
July 11th, 2003 08:10 PM #9ungas
plano ko nga yung stainless e kaya nga parang nagaalangan ako kasi di ko maisip kung saan ko itatago. yes ill try to check if ok nga yung nautilus ill just compare kung ano mas ok. nautilus or another pair of bosch europa.
btw anong horns yung pinaparating mo ke glennster? mukhang maganda ata yun a
July 11th, 2003 10:43 PM #10
rod..sabi nga ni kuya ronald..mejo mahina daw ung iyo.....sa wiring siguro yan....chekc mo ulit..sakin ang lakas talaga pag tine test namin eh..
ungas..may parating na 3!!!!
980 (discounted na yan ha...) ang nautilius..1
minsan naisip ko... is it really realistic to have a subway na project lang ng isang city? in this...
Makati Subway. Completion date: 2025
