Results 1 to 10 of 22
Tsikot Member Rank 4
- 1,842
November 21st, 2006 05:23 PM #197 Lancer GSR
(with cup holders)
1. At night time Malamig everything seems ok
2. Morning/afternoon under the sun on a stand still Sobrang init parang walang aircon
3. Morning/afternoon on good trafficc medyo may lamig
What could be the problem?
What are the parts to be replaced?
How much?
November 21st, 2006 05:34 PM #3
probably me pin hole leak yan. ganyan din yung symptoms nung revo ko. me nakita silang leak sa fittings ng compressor. pinalitan lang ng rubber bushing nung fittings ok na.
November 21st, 2006 05:39 PM #4
looks like a dying compressor
pa test mo muna compressor mo, ideal reading should be
on the low-side is 30-40 psi
on the high-side should be less than 200 with engine idle
if the low-side pressure is more than 40 and the high-side is still less than 200, maybe theres a problem with the expansion valve or compressor,
if the high side reading is 200+, that's what they call high pressure
HTH
edit: I'm assuming here your A/C system has no leaksLast edited by artpogi; November 21st, 2006 at 05:45 PM.
November 21st, 2006 10:41 PM #5
Sounds like the aux fan. Surplus is Php1,500 + a lil labor for install
Can also be a dirty condenser or an a/c comp that is not compressing like it used to.
November 22nd, 2006 12:12 AM #6on the low-side is 30-40 psi
November 22nd, 2006 07:36 AM #7
first of all I'm not an A/C technician, I was informed by my A/C tech friend about those readings.
IMO, basically what it meant is that those should be your pressure readings if your A/C system or part of your A/C system is in tip-top shape. Now if your readings are within those that I posted then I guess it is okay.
I have encountered the same problem as that of the thread starter and remember having my A/C checked and can't find no leak and the aux fan working fine, when we checked the readings it was not within the ideal range, so we deduced that the A/C compressor was on it's way out, true enough, when I replaced my compressor, everything turned back to normal
As for the "hilaw" na lamig after cleaning, it had happened to me and I have no answer for that, that is why now, if my A/C is working fine, I don't let anybody touch it, I don't have it cleaned unless I can feel that something is amiss. That's why when it comes to my A/C system my policy has always been "if it ain't broke, don't touch it".
HTH
November 22nd, 2006 09:14 AM #8
- 1,842
November 22nd, 2006 04:15 PM #9ARGH! Magakano kaya compressor?
Surplus or Brandnew? Replacement or orihinal?
given all your suggestion
the dillema now is finding a mechanic that would pinpoint exactly the problem
I dont wanna to do trial and error. Baka magend up ako na pinalitan na lahat.
Tnx s mga suggestion.
I hope its got nothing to do with my cupholders
November 22nd, 2006 04:25 PM #10
maxi...its somewhere from 10k-13k..
syempre, brand new. you can never go wrong with it. minsan kasi sa surplus, after a month or two, pwedeng mag break down ulit, mag dodoble pa expenses mo.
mechanic? si mang mario.
may connection ba yung cupholder mo sa aircon system mo? kasi kung meron, baka yun nga ang culprit. hehehehe.
or you may try calling up Coolmate, which is a service arm of Denso (Denso aircon ng Pizza eh.) based on the brochure that i have from them they can rebuilt compressors, which are quality guaranteed, using original abd nrabd new shaft seals and gaskets. Those parts which are out of specs are replaced with brand new parts.
branches:
Makati - Pasong Tamo Extension (867-3218)
Alabang - Motortown, ATC (8091924)
Caloocan - EDSA (3673351)
QC - E.Rodriguez (7276133)
Pasig - Ortigas Avenue (6321061)
Paranaque - A.Santos Avenue (5421484)
Quezon Avenue (9274417)
The Fort - (8182193).
Pa check mo muna sa kanila. May free checkup services sila.
hth.
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
