Results 31 to 40 of 43
- Apr 2010
- 29
September 29th, 2010 09:32 AM #31Sir no offense ment, but have you tried driving an OPEL M/T?!?!
Comparing the ride of Corolla and Sentra is like comparing Apples and oranges.
The stability of the ride
The feeling of solidness
The safety
The german technology (poor man's bmw)
The thinkness of the steel sheet of the body
Yung quietness sa loob ng car compared to the Sentra and Corolla of the same generation
I'm a ten year old owner of Astra and there is NO REGRETS whatsoever in my part and in my wifes part.
It's KNOWING where to buy the parts and where to have your car serviced which will make the difference! PM for details on how, where anything under the sun about opel astra. I'll try to answer
cheers!
p.s. before i agree the parts was expensive but the spare parts prices has gone down.
September 29th, 2010 09:44 AM #32
September 29th, 2010 09:48 AM #33
I agree with you sir. Pinsan ko naka-Astra 2002 model (the last batch that has arrived here), very solid pa rin yun kumupas na nga lang ang body color but aside from that, it is a much solid car compared to a Corolla or a Sentra. and yup, poor man's BMW nga ang Opel hahaha (heard this with my friend na naka-Astra din). I know Opel owners because yung pinapagawaan ko ng Zuki ko gumagawa rin ng Opel and Isuzu hehe (Olympia).
- Apr 2010
- 29
September 29th, 2010 10:07 AM #34
- Sep 2010
- 8
September 29th, 2010 01:43 PM #35
- Sep 2010
- 8
September 29th, 2010 05:47 PM #36
- Jul 2009
- 54
September 29th, 2010 06:02 PM #37
- Dec 2008
- 153
February 15th, 2011 08:30 AM #38the opel brand is german but the astra is not. most cheap plastic parts share with other GM units and are made from korea. But for it's current price in my opinion is a good buy. 200k for an early 2000 model astra wagon is better than getting a mid-90's corolla. Stay away from the vectra and omega. Astra is safe. There should not be a big problem as long as it's well-taken cared off. Engine power naman is subjective. Much better than powering your car with LPG. That's my opinion ha ghost hunter.
- Feb 2011
- 19
March 8th, 2011 04:53 AM #39Hi, all. I'm a new Astra owner(about 1mo)and it's the 1st car I bought myself. The car has some issues.
I also did some research and found you can get general error codes by doing a paperclip test or the pedal method and counting the 'blinks and pauses"-parang morse code.
I got:
P1700-transmission control unit-request MIL illumination
P0230-fuel pump primary circuit malfunction
P2106-no communications with engine control module
P0700-transmission control system malfunction
Nagpunta din ako to Motorex(banawe) tapos ito lumabas:
P0230 - Fuel Pump secondary circuit open
P0720 - Output Sensor Circuit Malfunction
A second scan at JSE showed
P0700 - Transmission Control System
P0753 - Shift solenoid A(1-2/3-4)circuit open (around Php3200)
P0716 - Turbine Wheel Speed Circuit malfunction.
The PC program(autodata cd2) they used at JSE also showed probable causes-wiring for all the fault codes. I looked up the program on the net and its around GBP550. Expensive.
The items in RED are the common faults and its mostly wiring. Does anyone know where I can have this done properly following the wiring diagram?
At least now I know that it's really not A/T problem.
Sa may Q.C. ako. may ma recommend ba kayo maayos gumawa ng wiring na sumusunod sa wiring diagram for the Astra?
Thanks!
- Mar 2011
- 5
April 3rd, 2011 09:11 PM #40benta ko opel astra red wagon 2002 running condition 0922858XXXX P250k may bibili kaya?
Xiaomi E-Car
