Results 11 to 20 of 54
August 11th, 2009 07:41 AM #11
itong nasa picture mo ay carb type iyong idling adjstment niyan ay nasa gilid ng carburator ang pagkakaalam ko. Sa carb type kasi pag adjust .Hinaan mo muna menor habang inaadjust mo hangin adjust mo iyong pinakamataas . at saka adjust mo na iyong menor. Pag adjust ng menor mas maganda kung mainit na makina mo. Ito lang ang opinion ko.
August 11th, 2009 12:38 PM #12
August 11th, 2009 12:40 PM #13
August 11th, 2009 01:09 PM #14
That's not a carb:
Clearly EFI (check out the fuel injectors by the cylinder head in the pic)
The black box with the gray connector on the left side of the throttle in the pic is the MAF housing. The small round port inside the throttle body is where the MAF wire is. The individual black connectors (four in all) by the cylinder head are for the fuel injectors.
The purplish looking one might be for vacuum... the brown connector above the gray one might just be the TPS, but without seeing it in person, I can't say that I'm 100% sure. This is one of those things where you'll have to consult a mechanic familiar with these engines to find out... or at least try to find the workshop manual.
August 11th, 2009 01:36 PM #15
workshop manual? ano po iyon? meron akong PDF na lahat ng description ng lahat ng piyesa ng auto ko andun pati pag gamit ng consult eh andun. ang problema lang eh pang DE yung manual ko at hindi pang DNE sakit sa ulo itong DNE na ito bakit hindi nalang kasi DE huhuhuhu biruin mo yun sa manual na cd na binigay sa akin ng friend ko ma pang ga14de ga16de sr20de pero walang ga16dne or ga14dne huhu
August 11th, 2009 02:16 PM #16
EFI na po ang Sentra EX (GA14DNE). I used to own one for 9 years until I sold it in 1997.
Re: idling screw, to my recollection, nasa ilalim siya ng of a certain part (can't remember kung TB or the MAF). Its a black thingy and located on the left side when facing the engine. Tinuro lang din sa akin ng Shell mechanic (Pook Ligaya station).
August 11th, 2009 02:23 PM #17
August 11th, 2009 02:23 PM #18
August 11th, 2009 03:36 PM #19
August 11th, 2009 06:49 PM #20
The perks of owning a rare engine... ...sorry... I feel for ya, bro... ganyan din ang feeling ko sa 626 dati.
Consider... at least mas simple siya compared to the regular GA16DE... mas konti ang vacuum hoses and connections, so it's easier to diagnose problems when you're familiar with the engine, already.
And it allows you to put on bigger and better intake tubes...
I just imagine it's a manual especially at low speeds or while maneuvering on inclines. Nature of...
(2023) Ford Territory
