Results 11 to 16 of 16
- Feb 2012
- 70
September 26th, 2012 05:17 PM #11
September 26th, 2012 06:07 PM #12
Not necessarily terribly matagtag... just more so than 55 series.
The difference in weight between 50-55 series tires of the same make and model is a mere 1-2 pounds per tire. If there is any. You're only losing a strip of rubber less than half an inch tall around the circumference of the tire. And worse, if the model you buy in 195/50 is naturally heavier (say, it has a rim protector, since it's a low profile tire), then it may even be heavier, despite being smaller.
This is not to say lightweight tires are not worth it, but that going down in size is not a guarantee that the tires will be lighter.Last edited by niky; September 26th, 2012 at 06:19 PM.
- Feb 2012
- 70
September 26th, 2012 08:56 PM #13mas ok na cguro tlaga ang 55 series. . kahit pa long distance mas kampante ka, . wla na bang mg tatangol sa 50 series dyn? hehe. . bukas na kc ako bibili ;)
- Feb 2012
- 70
- Feb 2012
- 70
September 27th, 2012 11:34 PM #16thanks sa mga input guys. . kakabili ko lang ng brand new 55 series tires, ngyn lang gabi. . more power sa tsikot. .helpful tlga. . salamat talaga, kayo na ;)
high idle RPM at engine start
