Results 121 to 125 of 125
February 2nd, 2005 09:42 AM #121
supposed to be no vibration, all other 4wds should have none, because some lock their hubs so that they dont need to "get out in the mud and lock your hubs". may client kami LC80 locked all the time na ang front hubs ya.
February 2nd, 2005 10:28 PM #122
balak ko nga din na always locked ang front hubs ko. sana maging ok na this saturday.
Signature
Tsikot Member Rank 4
- Feb 2004
- 1,704
February 4th, 2005 02:54 PM #124alam ko merong kit dati ang mitsubishi to make the 4x2 fieldmaster into a 4x4. they just removed some parts kasi para di masali sa excise tax ng 4x4 but in reality, madali na lang raw ibalik to 4x4.
andy
February 6th, 2005 10:36 AM #125
had the prop shaft replaced yesterday. still didn't have any weights attached to the shaft. ang ginawa daw ng Precision is inayos yung pagkaka-weld ng crossjoint sa shaft para pumantay yung ikot. hindi daw yata gaanong aligned or hindi maayos yung pagkaka-weld dati. so far, umabot na ako ng 120kph ng walang vibration, but it still felt different than having the front hubs unlocked. hindi ko mapaabot ng more than 120kph, kasama ko kasi dad ko kagabi
and did you know, i reached 100kph with my patrol yesterday in less than 5sec!!!! and starting from 5th gear pa yun!!! hehehehe, nasa sampa kasi sa lifter :bwahaha:Signature
high idle RPM at engine start
