Page 40 of 66 FirstFirst ... 3036373839404142434450 ... LastLast
Results 781 to 800 of 1303
    Apr 2010
    #781
    mga bro... pinatakbo ung vanette ko ng mga 110 kaso ung rpm ko hirap hindi umabot ng 3000.... ano kaya problem?
    #782
    EB na ulit..
    this is my spidey..
    A/C - front on steering wheel..rear on dash..
    how it crawls..
    innova chase..
    #783
    smoke emission result..
    itsura nya..
    #784
    Tsk..tsk..tsk.. Shauskie!
    Tindi ah! 140kph! Nakakatakot na speed yun! Pakiramdam ko na babaliktad ako nun!
    #785
    Quote Originally Posted by Godson View Post
    "Pedal to the metal" na ba? Or kelangang i-downshift mo muna para di mahirapan yung makina?
    #786
    Quote Originally Posted by macgyver1432000 View Post
    oo nga..pero pag may load ok lang handling kahit 160..stable..kupo sa tinampo..
    Apr 2010
    #787
    yup.. pedal to the metal na.... ayaw na tumaas ung rpm
    #788
    Quote Originally Posted by shauskie View Post
    Bros, I was able to run our Vanette at about 150KPH, along the STAR tollway stretch from Lipa to Sto. Tomas about 7 years ago....
    Fully loaded ako.... I noticed that as I gained speed, the van exhibited its road hugging properties, resulting to better handling >>> more stable driving....
    (May bumundol pa ngang ibon sa aking windshield that time,- mabuti na lang at hindi nabasag.... )
    11.3K:snow:
    #789
    Godson,
    Baka hindi nabatak mabuti yung accelerator cable sa carb ...or...
    wala naman sigurong nangangamoy na clutch lining ..
    #790
    11.3K:snow:
    tama..mababa rin kasi ang vanette kaya yung weight is near sa ground..kahit kurbada sarado ng 100 di pa tataob.. same experience..ibon din sapol pag take off nya sa kalsada..gilid naman ng windshield..
    *godson - add ko lang sa advise mc..check contact point ang gap..pag ok naman..check mechanical advancer ng distributor baka stuck up na kaya di na maka advance further yung timing kaya di na rin makabirit makina mo. gud luck bro..
    #791
    I agree with you bro, shauskie. I like driving our Vanette in high speed curves. Very stable. Hangga ngayon, ginagawa ko pa rin iyan just to check how good the suspensions still are,- okay na okay pa rin...
    Iyong dati naming Gen3 Starex,- walang panalo. Para kang tataob sa high speed curves dahil pronounced ang body roll...
    11.3K:snow:
    #792
    Maganda kayang i-lowered ang vanette, tapos offset ang gulong?
    #793
    bro i tried lowering my van, just removed the front rubber block and at the rear installed 2inch lowering block. AFter a month i returned the rubber block in front sobrang tagtag kasi, i know theres other way lowering it but ngyaon rear ko lang nakalowered..
    anyway ganda pag nakalowered front gapang na gapang ang looks poging pogi
    *ll
    anong offset ng van mag wheels natin? Gusto ko sana medyo luwa eh
    kaya lang nakakita ako ng 40+ offset papasok kaya?
    share ko na din baka type niyo
    http://www.sulit.com.ph/index.php/vi...rds=114+pcd+15
    what do you think guys?
    Apr 2010
    #794
    shauskie
    nagpalit nako ng contact point... hindi kya clutch ang kylangn kong pagawa?
    #795
    shauskie
    based lang sa problem description mo kasi the most probable cause will be ignition timing kasi di mo mapa rev ng higher ang engine. if clutch naman..probable effect will be higher rpm pero slow ang takbo or either mahirap ikambyo o madaling ikambyo kahit di mo apakan ang clutch pedal..
    kung sa gas naman..pupugak sya pag medyo kinapos on attempt to go up higher rpm..
    #796
    gud day po newbie here..............own a vanette 93'
    inquiry lang po......, how to remove yun coolerbox between driver/passenger seat gusto ko sana linisan/wash un carpet(DIY) wala kasi akong makita screw o bolt sa loob ng box bka po may idea kyo regarding this........ big thanks
    #797
    shaus! tulong....
    Hindi ko pa nababaklas ang cooler box ko... although disabled na ito dahil tinanggal na namin ang cooling coil.....
    11.4K:eathis:
    #798
    shaus! tulong....
    11.4K:eathis:
    sure bro cvt...
    *bokxz - welcome sa thread ng vanette bro..about sa cooler box..sa labas ng van ang access..sa ilalim ng flooring...natatakpan ng front ac condenser kya di mo kita..sipatin mo sa medyo gilid...4 nuts na 10mm lang yan. pero pag nakakabit pa yung conduit pipe for cooling coil ng cooler box di mo makakalas from van...kaylangan mo idischarge ang freon..hope this help..good luck pre..
    Jun 2010
    #799
    Musta na po to all ka vanette. busy parin ako sa baby namin kaya di makapat internet
    #800
    Quote Originally Posted by aijie28 View Post
    congratz pre aijie...malamang tanggal na boombox mo sa likod ng van mo at baby's stroller na ang kapalit na karga..hehe.. musta kay misis at new baby nyo..boy or girl ba?
Nissan Vanette [Merged threads]
