Results 1 to 10 of 11
- Feb 2010
- 4
February 24th, 2010 03:27 AM #1mga sir, may problema rin po radiator ko, i tried driving from cavite to makati, muntik na ako maoverheat, buti nakita ko umaangat na yugn temperature, puno yun ng tubig bago ako umalis, tapos may sumisingaw sa may bandang grill, upper left side ng logo nung nissan , newbie palang ako sa mga maintenance, this is my first car, got it a month ago, 2nd hand. anong suggestions nyo po, salamat po ng marami sa mga tutulong
- Feb 2010
- 4
February 24th, 2010 03:31 AM #2
- Feb 2010
- 4
February 24th, 2010 03:45 AM #3mga sir, may problema rin po radiator ko, i tried driving from cavite to makati, muntik na ako maoverheat, buti nakita ko umaangat na yugn temperature, puno yun ng tubig bago ako umalis, tapos may sumisingaw sa may bandang grill, upper left side ng logo nungnissan , newbie palang ako sa mga maintenance, this is my first car, got it a month ago, 2nd hand. anong suggestions nyo po, salamat po ng marami sa mga tutulong
- Feb 2010
- 10
February 24th, 2010 07:38 AM #4Have a mechanic remove the thermostat- that was what my mechanic did when i overheated
- Aug 2004
- 164
February 24th, 2010 08:35 AM #5
The thermostat is there for a reason......and a good one.
Avoid mechanics who rush into removing it unless it's the defective part.
Sumisingaw? me butas ang radiator?
Solution is to get it patched.
Maybe it's a "pinhole". You don't see the leak easily....but under pressurized conditions it will manifest.....then you lose coolant , result is overheating.
Get your radiator to a radiator shop and have it inspected, cleaned if needed.
Eliminate possible causes one by one starting with the radiator which is prime suspect in your case, IMHO.
Good luck
February 24th, 2010 09:01 AM #6
Your car is nearly two decades old. There is a number of stuff that can go wrong with a car of that age. One is rust clogging up the tiny tubes in the radiator. Another is a faulty water pump.
February 25th, 2010 08:10 PM #7
Maitanong ko na rin po, san po ba pwede buli ng radiator ng Series 3? Ano po ba ang mas maganda yung Brand New o yung Surplus? Thanks!
February 25th, 2010 08:43 PM #8
may evercool din ata for S3 tsaka sa S2. better to get this instead of getting surplus.
February 26th, 2010 06:17 AM #10
ikot ka lang sa banawe meron nyan.
punta ka kay speedyfix (search mo na lang ung map sa google), trusted shop dito yun. pag pinakalas mo yung radiator, sabay papalit mo na yung waterpump, timing chain, thermostat and the 2 electric fans.
bring the old radiator and fans with you when you go around banawe. punta ka mga surplasan, pakita mo yung dala mo sila hahanap ng compatible for you. tawad ka sa presyo, mga 500 ang ibawas nila per piece or so. balik ka kay speedyfix, kabit nila yun, and you're good to go.
ewan ko lang kung mag overheat ka pa nun.
PS: maghanda ka ng pera magastos ito. walang tipid tipid pag maayos na gawa... mas mura pa rin ito kesa ma-tirikan sa gitna ng ilocos norte papuntang pagudpod diba?
Goo gone or pwede oil. Babad mo lang para lumambot and mawala yun stickiness Sent from my...
Removal of Rain Visor and Chrome Door Handle and...
