Results 1 to 10 of 88
- Nov 2005
- 251
May 2nd, 2018 03:37 PM #2
July 18th, 2018 12:56 PM #3
- May 2014
- 1,319
July 18th, 2018 07:09 PM #4Yung sa di makaahon, malamang naninibago pa lang yung mayari ng CVT, or first time driving it.
Pag umaandar ka na and you stop the car for a bit then try to accelerate again, the transmission is not usually in the "First gear". Para bang nasa 2nd gear siya na pinipilit mo umahon paakyat.
You have 2 options, hold the brake long enough so the CVT shifts down to first gear, or shift it to low gear mode.
It is not a failure of the CVT but just that the driver is not used to the CVT.
Please take note, when CVTs first came to market worldwide, a lot of mechanics/owners didn't know that it used a different type of transmission fluid, CVTF, not ATF. Some owners mistakenly changed the fluid to ATF causing problems to the transmission.
Additionally, CVTF needs to be change depending on use case scenario or mileage. Ive already had my CVTF Checked and it is still clean enough to use. Normal CVTF interval for full replacement is around 80k if memory serves me right, but if you are always stuck in bumper to bumper Manila traffic, that 80k mileage will drop down. So you have to have your casa check the quality of your transmission fluid to make sure it is still usable or if it needs replacement.
I'm very happy with my Sylphy CVT, still smooth. If Nissan tells me to change CVTF, I'd gladly pay for the replacement than risk damaging my transmission and shelling out for a bigger headache down the line just because I wanted to scrimp in the maintenance expenses.
Family also owns a Honda City 2007 model i-Dsi with CVT. That required CVTF change when the transmission started to jerk a little in low gears, luckily the belts weren't damaged (these were connected to the manual mode which is prone to failure on this model). I think the mileage for that was around 60k only. Was able to save the transmission in time by having it checked else I'd need to shell out around 40k minimum based on other owners of the same car who suffered with the transmission.
So Honda, for its part, also had CVT woes. It was only until recently that Toyota shifted to CVTs right?The previous gen altis was regular AT only. Only the current gen Dual VVTi model are using CVTs.
Regular AT also needs to change ATF. I cant remember the interval of changing it though but I know it is not as "sensitive" since gear ratios are fixed.
May 2nd, 2018 03:44 PM #5
which is non cvt in nissans lineup aside from their diesel pickups and vans?
FOCUS
July 18th, 2018 03:08 AM #6
saw a nissan altima maybe a 16 or 17... cant get over an incline [emoji28]
July 18th, 2018 06:37 AM #7
What kind of incline are you talking about? Just wondering because we recently got back from 2 road trips where we took highways that went up the Arizona mountains. No problems keeping up with the 65 mph speed limit (we were doing 70 mph) while climbing and with a full load of passengers/luggage.
Oh. We used the wife's 2013 Rogue SV.
July 18th, 2018 10:07 AM #8
Our 2015 CVT equipped Xtrail is purring along nicely as well. This one has 70Tkm on it.
Remember when people used to shy away from A/T's because they say they wouldn't last as long as M/T's? These days you practically have to beg someone to buy your old M/T car. Early versions of new tech will always have their teething problems.
I also suspect some of those failures had a lot to do with the CVTF not being changed at the right intervals (if at all) or replaced with ATF 😱
- Sep 2007
- 267
July 18th, 2018 07:30 PM #9
July 18th, 2018 08:02 PM #10
#6 and #19
Car Problem Trends | CarComplaints.com
No, but it was what sounded closest to Bill, bill. Ha ha ha!
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
