Results 31 to 40 of 42
April 6th, 2012 12:24 PM #31
Try giving Jemson (Otep's electrician) a call. Reys also does homeservice pero hatid-sundo.
Hows your transmission? I saw a B14 Sentra undergo ATF dialysis at Exalta in Banawe and this cured his sliding transmission problem; its not guaranteed to fix it but maybe it would help as this will flush the entire ATF system.
- Apr 2012
- 3
April 6th, 2012 02:18 PM #32
- Apr 2012
- 3
April 6th, 2012 03:32 PM #33
- Jun 2004
- 185
April 7th, 2012 01:49 AM #34Thanks. I will try to contact them.
Re battery: Apparently it's just a battery (completely) discharge issue.
I sent the battery to Motolite Dealer near my place and have it charged for at least 6 hours (Php 60.00), then viola my old car went back to life. Yun nga lang super hard start sobra, namamatay sa una, mga 15 times ata ako nag try mag start, nag start ng about 2 secs, then deads ulit.
Hindi nakaya ng pag series, dahil siguro completely discharged.
About dun sa transmission: Hindi pa sya ganun ka-ok, pero hindi na tulad ng dati after changing ATF, kasi dati, need to hit 60kph before it will engage sa D, ngayon, just run the car at any speed for at least 10 secs then pwede na sa D.
- Jun 2004
- 185
April 7th, 2012 01:51 AM #35
- Feb 2008
- 17
- Jun 2016
- 2
June 13th, 2016 09:41 AM #38anyone naka altima user here? plano ko bilhin yung altima ng kakilala ko may some questions lang po ako thanks!
- Jun 2016
- 2
high idle RPM at engine start
