Page 1 of 2 12 LastLast
Results 1 to 20 of 53
    Jan 2013
    baka matulungan nyo ko, pag nag menor ako pag tapak ko uli sa gas e kumakadyot kadyot ang takbo niya, matagal ko na kasing pinagagawa e ganun parin, posible bang sa clutch un. tnx sa mga mag rereply.
    its either:
    a) dirty injectors
    b) worn out high tension wires
    c) dirty MAF
    d) dirty air filter
    e) dirty fuel filter
    Quote Originally Posted by 1D4LV View Post
    Its either:
    a) dirty injectors
    c) dirty MAF
    d) dirty air filter
    Agree here, best to do it in this order:
    Start with cleaning the MAF, checking the air filter and changing the fuel filter. Then you move on to injectors and HT wires if it persists.
    Jan 2013
    salamat po vinj, tanong ko lang po kasi wala pa po ako masyado alam sa makina, ano po ung MAF at san po siya makikita sa makina.
    Quote Originally Posted by cape59 View Post
    MAF is mass air flow sensor. Its located inside the throttle body. Hwag mo na lang muna galawin ito kung medyo baguhan ka, very sensitive itong part na ito, and pag na damage ito, may kamahalan.
    Non contact spray ginagamit panglinis sa MAF. Wag mo na attempt na hawakan or punasan yun.
    Jan 2013
    salamat po sa paalaala nyo, pa che check ko na lang po sa mekaniko. thanks po uli 1D4LV.
    Jan 2013
    salamat po 1D4LV
    Sa tingin ko, fuel filter pa lang solb na problema mo.
    Hindi ka na sana nahpalit ng AT.
    San ka ba located Sir.
    May 2015
    Quote Originally Posted by RomeoAlpha View Post
    Sana nga fuel filter lang. Bad trip yung mekaniko namin dati eh. Sya rin kasi mekaniko nung Isuzu namin kaya sa kanya na rin kami nagpatingin nung Nissan
    Taga Las Pinas ako pero mekaniko namin sa Imus malapit sa LTO
    Mar 2015
    Since nasa bacoor kayo sir why not try our mechanic here near sm molino.in our circle of friends here we have 5 sentras which our mechanic maintains. And none of us have these kind of problems with our sentras
    May 2015
    Quote Originally Posted by SkyFlakes88 View Post
    Sir sa may SM Molino lang? Taga Maricielo kami so malapit lapit ng kaunti. Sige sabihin ko sa wife ko na dyan muna kami punta. Pilitin ko sya this Saturday puntahan nyan
    Ano pangalan ng shop? Pwede kaya patingin muna namin para maliwanagan kami sa totoong problem. Naguguluhan na rin kami eh
    Ano mga Sentras nyo? Series 3 yung sa amin B14 body. In addition sa mga nabanggit kong problems medyo mahina rin yung aircon chaka yung odo pumipitik pitik hanggang sa red line (parang grounded lang ata yun eh)
    Thanks in advance!
    Mar 2015
    Sir actually coming from paliparan before sm pa kami. Yun entrance nang bellefort estates yun amin. Our car is a b13 yun mechanic b12. You can dropby sat or sun. Wala pong shop he lives here. Ygpm sir
    May 2015
    Got this sir. Salamat sa tulong. Bukas papatingin namin sa bagong mekaniko namin at lilinisin daw nya distributor cap at papalitan ng fuel filter. Pag di gumana yung mga gagawin contact namin yung mekaniko. Salamat uli
    May 2015
    Update lang...
    Pinalitan yung air filter at fuel filter nung Nissan namin. Lininis din lahat ng hoses. Nag test drive kami Bacoor to Baclaran via Coastal Road and walang kadyot kahit 100kph yung takbo. Observe ko muna ng 1 week. Sana tuloy tuloy na improvement. Salamat sa mga nag advise at sa mga suggestions
    Hindi napalitan yung distributor cap kasi walang makita dito sa amin. Lininis na lang nung mekaniko.
    Sunod na papatingin ko sa sweldo yung aircon. Hindi na sya lumalamig. Nung nakuha namin yung sasakyan pinalinis namin aircon at naglagay ng freon pero ever since walang improvement. May iba pa bang kelangan pa check sa aircon? Yung sinasabi nilang ice cold aircon ng Nissan di namin nararamdaman
    Quote Originally Posted by chococarlo View Post
    Update lang...
    is the evaporator original or replacement? is the thermostat a bright rectangular thingee about 2 x 1 x 1 inches, with long metal "antenna-like" temp sensor, under the dash, near the floor?
    if yes to both, then i think you have a mismatch. replace the evaporator with an original design, and have that thermostat removed, in favor of the original.
    the original temp control is a baraha-sized, flat black thingee about three inches long to the side x 1/2 inch thick, behind the dash panel temp control knob.
    there are two types of evaporators: serpentine and laminated. one is cheaper, and the other, more expensive one, is what the sentra aircon wants. alas, i forget which one it is..
    i used to have this mismatch... the evaporator kept freezing up...
    May 2015
    I am not sure if the evaporator is an original or a replacement. I will have it checked sometime next week. If I replace it with the original (evaporator and thermostat) how much would it cost? Malamang sa surplus kami kumuha. Know any reliable Nissan aircon specialists sa Las Pinas or Bacoor area? I will ask the mechanic kung may kakilala rin sya
    Thanks as always!
    Mga sir need your help.planning to buy a nissan sentra lec ps 1998 for 89k.makinis p sya.ok po b ang price
    Mar 2015
    Quote Originally Posted by reirocel View Post
    The price is ok but try to haggle a bit more to 75 to 80k range. Can you post some pictures of the car sir?
    do not judge a book by its cover. for an old car. the seller will try to sell by its looks.
    quick checklist.
    -engine(belts pulleys spark plugs coolant. ). last oil change? fuel filter changed? check for cracks in the exhaust manifold, engine mounts ok?
    -check the chassis for rust, for an old car there could be some really bad rust. this could be the deal breaker.
    -last transmission oil change?
    -suspension and brakes- tanggal gulong and open the drum brakes, also brake pads.
    -battery test also. baka kailangan palitan. if you know the price of the battery baka masurprise ka.
    -test drive.
    all your "findings" will require deduction from the sellers price.
    quick checklist.
    -test drive.
need help on my nissan ex saloon series 3
