Results 21 to 30 of 53
- May 2015
- 19
May 14th, 2015 06:27 AM #21
May 14th, 2015 08:37 AM #22
Since nasa bacoor kayo sir why not try our mechanic here near sm molino.in our circle of friends here we have 5 sentras which our mechanic maintains. And none of us have these kind of problems with our sentras
- May 2015
- 19
May 14th, 2015 09:00 AM #23Sir sa may SM Molino lang? Taga Maricielo kami so malapit lapit ng kaunti. Sige sabihin ko sa wife ko na dyan muna kami punta. Pilitin ko sya this Saturday puntahan nyan
Ano pangalan ng shop? Pwede kaya patingin muna namin para maliwanagan kami sa totoong problem. Naguguluhan na rin kami eh
Ano mga Sentras nyo? Series 3 yung sa amin B14 body. In addition sa mga nabanggit kong problems medyo mahina rin yung aircon chaka yung odo pumipitik pitik hanggang sa red line (parang grounded lang ata yun eh)
Thanks in advance!
May 14th, 2015 01:15 PM #24
Sir actually coming from paliparan before sm pa kami. Yun entrance nang bellefort estates yun amin. Our car is a b13 yun mechanic b12. You can dropby sat or sun. Wala pong shop he lives here. Ygpm sir
- May 2015
- 19
May 14th, 2015 09:13 PM #25
- May 2015
- 19
May 19th, 2015 12:48 AM #26Update lang...
Pinalitan yung air filter at fuel filter nung Nissan namin. Lininis din lahat ng hoses. Nag test drive kami Bacoor to Baclaran via Coastal Road and walang kadyot kahit 100kph yung takbo. Observe ko muna ng 1 week. Sana tuloy tuloy na improvement. Salamat sa mga nag advise at sa mga suggestions
Hindi napalitan yung distributor cap kasi walang makita dito sa amin. Lininis na lang nung mekaniko.
Sunod na papatingin ko sa sweldo yung aircon. Hindi na sya lumalamig. Nung nakuha namin yung sasakyan pinalinis namin aircon at naglagay ng freon pero ever since walang improvement. May iba pa bang kelangan pa check sa aircon? Yung sinasabi nilang ice cold aircon ng Nissan di namin nararamdaman
- 52,698
May 19th, 2015 01:58 AM #27is the evaporator original or replacement? is the thermostat a bright rectangular thingee about 2 x 1 x 1 inches, with long metal "antenna-like" temp sensor, under the dash, near the floor?
if yes to both, then i think you have a mismatch. replace the evaporator with an original design, and have that thermostat removed, in favor of the original.
the original temp control is a baraha-sized, flat black thingee about three inches long to the side x 1/2 inch thick, behind the dash panel temp control knob.
there are two types of evaporators: serpentine and laminated. one is cheaper, and the other, more expensive one, is what the sentra aircon wants. alas, i forget which one it is..
i used to have this mismatch... the evaporator kept freezing up...Last edited by dr. d; May 19th, 2015 at 02:07 AM.
- May 2015
- 19
May 19th, 2015 02:20 AM #28I am not sure if the evaporator is an original or a replacement. I will have it checked sometime next week. If I replace it with the original (evaporator and thermostat) how much would it cost? Malamang sa surplus kami kumuha. Know any reliable Nissan aircon specialists sa Las Pinas or Bacoor area? I will ask the mechanic kung may kakilala rin sya
Thanks as always!
- 52,698
May 19th, 2015 02:28 AM #29- - - - - - - - - - - - - - - - - - - - - -
a brand new evaporator of the right type for the sentra, will probably cost you a small arm only.. less than 10K.. the cheaper one, which is not what sentra wants, costs less than 3K, brand new.
i would avoid surplus evaporator, if my budget permits.. a surplus one might spring a leak every month, if it is "too old".. but chamba-chamba lang yan.. but a surplus temp control card is ok, i suppose.. mine cost less than 2K..
i have my aircon needs done in banawe QC.. medyo mahal si suki ko doon..
- May 2015
- 19
May 19th, 2015 02:40 AM #30Wow medyo mahal pala. Baka di muna pumayag si misis sa aircon repair. Papatingin ko na rin sa mekaniko kung ano recommendation nya.
May sinabi sya kanina na medyo may sakal daw yung Nissan. May adjust sya para daw di sakal at di bumaba RPM pero pansin ko pag traffic bumababa RPM nya to the point na parang titirik. Minsan nga pag reverse ako bababa RPM at natirikan na rin ako eh. Sabi observe daw muna
Baka puntahan ko na yung recommended Nissan mechanic na nasa Bacoor para ma resolve na lahat ng issues ng Nissan namin. Bebenta na dapat ito kaso sayang naman kasi wala pa 4 months sa amin eh chaka di pa deliver yung G4. May mga nakausap din ako na konting maintenance lang at linis linis gaganda pa takbo
One dude told me it was Li-Ion. Another dude corrected him. AFAIK the Zenix gets the Li-Ion hence...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
