Results 11 to 16 of 16
March 15th, 2010 12:43 PM #11
Echo nickriingen... proper timing advance for the Sentra is around 10 degrees BTDC.
But change your wires and have your distributor checked... 228k kms is a looooong way to go on just the stock wires... especially in our tropical heat!
March 16th, 2010 08:18 PM #12
Nagpalit kasi ng front oil seal... Possible na maiba yung timing marks dun?
Nakasentro naman yun distributor pero yung timing base sa timing light ay wala sa 10 deg. BTDC nasa below -5 deg BTDC, wala nga sa timing marks... pero ok hatak naman sya so far..
Hehe! Yeah it quite served us from generation to generation. Haha!
Anyways is NGK better than Bosch or any other brands? I'm trying to scout NGK HT wires around our area but I haven't seen 1 yet.
Sa totoo lang dinala ko sya sa shop malapit sa amin at ginamitan sya ng timing light kaya dun ako nagtaka kung bakit wala sya sa timng tapos nung sinagad sa advance yung distributor ang timing nya ay sa 3rd line (-5 deg. BTDC) kaya nag taka din ako...
Hindi nga kaya sa HT wires ang mga ito? Maitry nga mag palit... Mga magkakano kaya ito?
Tanong ko na rin mga ginoo kung ang 0 deg BTDC = TDC?
Thanks!
More power to tsikot.com and to its members!!!Last edited by kurby; March 16th, 2010 at 08:21 PM. Reason: Grammatical error
- Mar 2010
- 19
March 17th, 2010 06:19 AM #13got this same problem. timing and hatak was fine before i had the head gasket replaced. idling is just fine but im having problem with the lack of power. till now, the car, lec 97, is still in the shop. i told the mechanic to observe how it does. martes ko pa iniwan sa kanya, kukunin ko sa friday. sana, may hatak na. we suspect its the timing when the other mechanic replaced the head gasket..
- Feb 2008
- 76
March 17th, 2010 10:02 AM #14paps na experience ko sa kotse ko kapag wala sa timing mahina ang hatak at ang bagal mag accelerate, di pwede ang tantyatimimng
dapat gumagamit talaga ng timing light.
March 24th, 2010 04:25 AM #15
Yan po yung image ng distributor ko na meroong marks i think its for the 10 deg mark however it doesnt read 10 deg sa pulley...
- Mar 2010
- 19
April 4th, 2010 04:23 PM #16
The assumption that the vehicle runs on the road, the ECU is more than likely a match. Try cleaning...
***HELP*** iding problem
