Results 11 to 18 of 18
- Jul 2011
- 399
August 11th, 2011 11:38 AM #11Pcv yata tawag doon. Sorry talaga ha kasi its been a longtime that i sold my sentra kasi.
- Nov 2010
- 12
August 11th, 2011 03:40 PM #12slamat sir sa mga reply nyo... sabi ng mekaniko na tumingin ng isa. baka servo daw problema.... eh mahal po yun di ba? advised naman po kug eto talaga yung problem? thanks
- Jul 2011
- 399
August 11th, 2011 03:55 PM #13Sir wala sa servo yu. Problem kung idle drop lang yu issue. Puede naman niya check thru voltage meter kung sira yun servo. Im quite sure doon lang yun problem. Parang ficd tawag sa assembly na yun. You just have to clean this. I clean might before every race event before. Sa daily car naman twice a year ko clean yun sa b14 sentra
- Jul 2011
- 399
August 11th, 2011 03:58 PM #14Kung servo po yun problem sir hindi na dapat starting yun engine at all or kung starting ma magiging erratic yun rpm ng b13 po ninyo
- Jul 2011
- 399
August 11th, 2011 05:14 PM #15Sir, do not alter the electrical wirings of your car. Ibalik mo yun aux fan sa OE set up. Kug minsan matagal lumamig then you need to have your aircon check up na at baka madumi na siya and due na for cleaning.
Overheating sa sentra usually happens sa busted by pass hoses, kulang sa water(leak), madumi na yun radiator, busted thermostat
- Nov 2010
- 12
August 12th, 2011 05:54 AM #16Thank you sir... gagawain ko po sya mamaya after office hours.... feedback na lang po ulit ako sa inyo...
- Jul 2011
- 399
August 12th, 2011 08:15 PM #17Sir, dont use open type wrench in lossening the pcv, if im not mistaken size 17 yata yun
- Nov 2010
- 12
August 15th, 2011 07:22 AM #18thank you sir... buti na lang di ko nabubuksan.... Sir, ask ko lang na rin po.. kasi nung saturday and yesterday, pag-start ko ng car ko tapos binuksan ko yung aircon.. hindi umandar yung fan... ang tagal tuloy lumamig nung aircon.... napapansin ko pag-umandar na yung fan saka sya lumalamig... (Aux fan and fan ng aircon magkasama na). Ano kaya problem kaya neto , sir... salamat po.
high idle RPM at engine start
