Results 21 to 21 of 21
March 27th, 2012 07:33 PM #21
speaking only for toyota, i asked toyorama kung yung orig brake pads ba comes with new shims/retainers. wala daw, pad lang.
question: is your rotor stock or changed to slotted and drilled? when i had my warped rotor changed it had that loud tok tok sound after a day of use. yun pala parang sumasabit yung pads ng isang side sa slotted parts ng rotor. after sanding the pads nawala naman. kahit bago pa lang pads na yun, bought another pair of the same bendix gen ct and installed it myself. so far wala naman nang problema.
high idle RPM at engine start
