Results 1 to 6 of 6
- Mar 2012
- 16
August 19th, 2012 05:17 PM #1good day fellow forumers.. the clutch release bearing of my sr20de is subject for change.. i just do not know how much will it cost if i am going to change.. guys, which is better? is it buying a surplus tranny or just change the defective parts.. anyway, it's a manual tranny..
August 19th, 2012 05:31 PM #2
if your transaxle is not exhibiting any symptoms or problems, you might be better off with that one instead of an unknown condition used (surplus) one. clutch set is an expendable set of components: clutch plate, throw out bearing (clutch release bearing), pilot bearing and pressure plate. as with other operations, while the related parts are exposed ( rear crankshaft seal, transaxle input shaft seal), it would be a very wise decision to include them in the maintenance procedure. the seals might not be leaking now, but it won't take long before they do and the labor bill will probably be the same amount for the clutch replacement.
- Mar 2012
- 16
August 19th, 2012 05:46 PM #3
August 19th, 2012 06:09 PM #4
that is a very common and possible symptom after having driven or fording through flooded streets. if the clutch is not slipping yet and the odometer is below 100'000 kilometers, just bear with the noise. just be prepared for the clutch, oil seals replacement though
- Mar 2012
- 16
August 19th, 2012 06:28 PM #5
August 19th, 2012 06:32 PM #6
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
