Results 1 to 3 of 3
- Sep 2008
- 2
September 26th, 2008 09:18 PM #1is it applicable to use this energy saving aerogas gadget i Z24 engine. it will not give any harm for the performance of the car.
Tsikot Member Rank 3
- Nov 2002
- 1,757
September 26th, 2008 11:56 PM #2i think there have been threads about fuel-saving devices. though i'm not familiar with aero-gas, i suggest don't. better pang ipa-lpg mo na lang. though mas mahal ang initial cost, mabilis naman recovery. make sure lang na ok yung dealer at installer ng kit.
September 27th, 2008 08:40 AM #3
Aero-Gas is another so-called fuel saving device similar in operation as the infamous Khaos. All it does is let more air into the intake manifold resulting in a more lean burn in the engine.
If your engine is carburated, you can get the same results with tuning or changing the jet size to a smaller one.
If your engine is EFI, you won't get any positive results unless your engine to grossly out of tune and needing to be serviced/repaired.
In short, you don't need devices like that.
high idle RPM at engine start
