Results 1 to 3 of 3
    Sep 2008
    is it applicable to use this energy saving aerogas gadget i Z24 engine. it will not give any harm for the performance of the car.
    i think there have been threads about fuel-saving devices. though i'm not familiar with aero-gas, i suggest don't. better pang ipa-lpg mo na lang. though mas mahal ang initial cost, mabilis naman recovery. make sure lang na ok yung dealer at installer ng kit.
    Quote Originally Posted by royanthony View Post
    Aero-Gas is another so-called fuel saving device similar in operation as the infamous Khaos. All it does is let more air into the intake manifold resulting in a more lean burn in the engine.
    If your engine is carburated, you can get the same results with tuning or changing the jet size to a smaller one.
    If your engine is EFI, you won't get any positive results unless your engine to grossly out of tune and needing to be serviced/repaired.
    In short, you don't need devices like that.
aero-gas unit in Z24 engine nissan terrano
