Results 11 to 15 of 15
- Jul 2009
- 105
July 29th, 2009 04:11 PM #11
- Jul 2009
- 105
July 29th, 2009 04:20 PM #12Chief, sorry I forgot to mention this in my initial post. Here is my issue with the AC before. A couple of weeks ago, nade-delay kase yung pag-ON ng AC ko, kahit matagal ng naka start yung engine and kadalasan mga 30mins nako bumibiyahe eh hindi pa rin sya ng-o-on. Mainit na hangin lang yung lumalabas sa kanya.
I thought it was an electrical issue so dinala ko sa talyer and they said that the "electronic relay" was already busted so they had to replace it with a "mechanical relay", and so they did and that fixed the problem naman. They said that the electronic relay can only be bought sa casa and it cost about P3k already.
Question: Tama ba yung ginawa nila? tama ba na pinapalitan ko yung electronic relay with a mechanical relay?
Thanks again for your time mga chiefs.
- Aug 2009
- 7
September 1st, 2009 09:01 PM #13Sa tingin ko po, ok lang naman kung yung relay lang ang pinalitan, it acts like a switch lang naman po that turns ON and OFF your condenser. Pero wag lang nila papalitan yung thermostat from Electronic to mechanical, kasi di mo na magagamit yung adjustment sa console mo, instead temperature sensitivity adjustment has to made manually, ikot ikot ng knob. Eto po ay opinyon ko lamang..
September 2nd, 2009 03:00 PM #14
pa tune mo sa casa para sa idling issues. baka madumi na nga throttle body niya. sabay mo na rin palit ng spark plugs. kunin mo ngk-bkr5egp (bkr6egp will also do). tapos linis or palit ng air filter. check mo rin distributor cap mo kung may cracks or kinalawang yung contacts sa loob. yung high tension wires, palitan mo na din kung may cracks na or kung more than 3 years na siya.
September 2nd, 2009 03:38 PM #15
When i had my B-13 . Regarding the problem on idle issue. I Bring it to Nissan Quezon Ave. Branch .One of a friend in NISSAN BAYAN .COM recommend me .He just put a consult for a diagnostic test .He told about my Idle air control Valve problem . He did not charge me anything .
Regarding the thermal wrap as long as your radiator , auxillary fan ,radiator fan work properly no need to put thermal Wrap.
