Page 1 of 65 123451151 ... LastLast
Results 1 to 20 of 1287
    Aug 2012
    Has anybody seen this new pickup of Nissan already? Is it already available in their showrooms? Any comments?
    Apr 2006
    imageuploadedbytsikot-forums1424016394.408414.jpgimageuploadedbytsikot-forums1424016445.025420.jpgrear suspension
    Apr 2006
    4x4 manual
    Apr 2006
    Dimageuploadedbytsikot-forums1424016530.266303.jpg dashboard
    Apr 2006
    imageuploadedbytsikot-forums1424016652.445164.jpg rear suspension and differential
    Aug 2012
    I saw already one on the road along UN and Quirino Avenue extension, it looks GREAT, honestly. Looking forward to replace my Ranger with this one after 2 more years, no regrets with my Ranger, I had it for almost 3 years already.
    Oct 2014
    Nissan Navara:
    (My own observation)
    Likes: Road Presence, Looks, Design, Engine power, Features.
    Dislike: Interior color (i prefer Beige color)
    Was able to check out the 4x4 VL and 4x2 EL AT variants. Looks really great in the flesh and is way better than the previous model. I initially thought the 4x2 EL AT was the best value for money but after seeing both units, I think the 4x4 VL AT is the bang for the buck model.
    The 4x2 EL loses all the electronic tech features along with the 4x4 capability and higher torque/HP. I maybe wouldn't mind that so much but here are some other features of the 4x2 EL AT that I did not like, or was not willing to settle for.
    1. 16" wheels - the 18" rollers on the 4x4 version was way better to look at. It may cost in excess of 100k to replace this with 20" aftermarket wheels. I've "heard" the PCD of Nissan's tires have fewer aftermarket options.
    2. Regular 2-Din Head Unit - I wanted a HU with GPS and rear view camera. It might cost 40k+ to get this replaced with a better one. The stock HU of the 4x4 VL isn't really great, with a small 5" monitor, but at least it already has GPS and rear view camera. I can live with this.
    3. Multi-reflector halogen HL - I was disappointed that the 4x2 EL AT was not equipped with the LED projectors and LED DRLs. Nothing against the halogens but projector headlamps, especially LEDs have a way of spoiling you and giving you more confidence at night. This cost a fortune to upgrade, and the thought of voiding warranties does not sound reassuring.
    Other than that, it is basically the same specs for both models. I probably would spend slightly less to upgrade these 3 things but didn't want the headache of going that route. I would settle for the 4x2 EL AT if it is going to be a secondary vehicle, but might get the 4x4 VL AT since I intend to make it my primary ride.
    Test drives start Feb 21, as informed by the SA.
    Cost of maintenance seems to be a good selling point too.
    Mar 2003
    Hows the height of the 4x2 EL? Is it comparable with the 4x4? Just like the ranger? Thanks
    Quote Originally Posted by attorney View Post
    Ground clearance and overall height is almost the same, give or take a few mm. This is mainly due to the 18" tires and the addition of roof rails on the 4x4 variant. This model has higher ground clearance than the previous model and is about the same height as the Ranger pick-up. Published wading capacity is lower than that of the Rangers (800 vs 600mm), but I don't think I'll be testing this in flood waters that deep.
    Pano kaya naging low pms? Ilan ang fuel filter nito? And bakit 7L lang ang oil, YD25 sump is almost 8L. Goodluck sa 20k interval, sana ayos na timing chain tensioneer nito.
    ^Siguro dahil every 10,000Km yung service interval ng new vs 5,000Km for the old model = Low PMS. Good luck kung isa lang ang fuel filter hehe. 7L change oil dahil di siguro nasisimot yung nasa sump pagpalit. I think it's good that they've brought back service costs to reasonable levels. A lot of other makes are charging exorbitant rates right now.. I hope they can stick with the lower rates,
    Mar 2003
    Quote Originally Posted by disesaki View Post
    Thanks boss. So installed with same tires as 4x4 same na sila then
    I don't think it's the rim/tire combo, as both 4x4 and 4x2 Calibre rim/tire combos are 30" in diameter. Anyone think it's strange that Nissan keeps putting 255 wide tires when everyone else is using 265?
    The top tier 4x2 is disappointing.. Stripped down compared to Ford's. Oh well. I'm curious to see how the new 7 speed matches the updated yd25. Pag di ako tinamad sa Friday traffic I'll go for a test drive.
    Would love to see one with the awesome 285/60 R18 wheels of the Patrol, which could make the ride height, at least for the 4x2 variants, on par with the 4x2 XLT Ranger. It seems to fit the all-new model very well.
    The truck really has competitive specs, though for me, I saw that it has some niggles: the ride height or stance is kind of underwhelming for such a large truck, maybe due to combination of somewhat small tires & wheels. 4x2 EL Calibre variants could have had standard audio & cruise controls in the steering wheel and for the TOTL 4x4 variants, the seats and the side pads, as well as the other pads inside the cabin, could have been in leather, too. All of these, I think, can be already found even in the 4x2 Ranger Wildtrak but the Navara does make up for it, though, with a stronger engine, lighter weight, 7-speed a/t and the fact that it also comes with standard rear a/c vents.
    Despite those mentioned niggles, the 4x2 variants are still decent when it comes to features, but of course, TOTL 4x4 variants are much better to have because they possess many newer features compared to the 4x2s and the older models.
    Sep 2009
    Sino po may alam if Timing belt or Timing Chain ang bagong Navara? Yung verified po sana..
    Mar 2015
    Good day.. Are the nissan dealers offering discounts for the navara np300? In my place, mitsubishi is offering Php 65T off for the 2015 strada plus an all-in package. Not to mention the bunch of accessories as freebies. TY
    *I'm new here in tsikot.
    May 2008
    I'll be getting the 4x2 a/t EL calibre, all the features is just about right for its price
Nissan Navara NP300
