Results 1 to 15 of 15
    Hi guys, i am getting ready to have my radiator coolant replace. any suggestion as far as what to use or brand? i have a 2011 urvan and the coolant
    thats in there now is still the original coolant im thinking Preston any comment or advice?
    thanks
    Coolant ng shell maganda. Search mo yung review sa abroad. Aam ko highly praised yun. Then lagyan mo na din ng redline or royal purple water wetter
    Any decent brand will do. Just make sure na Hi-concentrate coolant ang bilhin mo dahil lugi ka kung pre-mix. Just use distilled water with 50:50 ratio.
    thanks bud
    Quote Originally Posted by s_quilicot View Post
    appreciate the advice
    ang aga mo naman magpalit ng coolant.
    Quote Originally Posted by robot.sonic View Post
    is a uv express van.(pangpasahero) that why
    ah. oks. hehe
    Quote Originally Posted by TONDOBOY1979 View Post
    If thats the case, mas maganda nga kung may watter wetter kayo sir.
    Jul 2011
    meron ba sa ace nito..
    ^Walang Water Wetter sa ACE.
    At Shang EDSA Plaza, they have RP Purple Ice at HANS Tools.
    You can buy Water Wetter from the race shops such as Speedlab and Autoplus. Baka sa sulit meron din.
    I had my coolant replace at shell and used their coolant brand, but to my amazement the radiator only took 6 liters instead of 12 like the manual indicate what gives??
    Nagbaklas ba kayo ng thermostat to drain? If not, most likely may naiwan pa na tubig sa engine block.
    no we did not remove the thermostat.is there a way to drain the coolant in the engine without removing the thermostat? or how to drain the left over coolant in the engine ? we even drain coolant in the sub radiator.
    actually i have been told to drain all the coolant out of the system engine/radiator you have to run the engine and disconnect one of the hose while running the engine to pump out all the coolant inside the system.
2011 urvan radiator coolant
