Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    May 2013
    Mga sir..
    hingi po sana ako expert advise..
    anu po pinkamaganda ipalit n engine sa oto ko.. GA14DE ung nkalagay sa knya ngaun..
    gusto ko po sana palitan.. anu po ung best n ilagay n my mbibilhan p ko n sure n di ko n kelangan gastusan ng malaki..
    thanks mga boss...
    Oct 2005
    SR18 or SR20DE
    Feb 2012
    Quote Originally Posted by basti08 View Post
    SR18 or SR20DE
    plus 1 kay sir Basti pede din GA16DNE or DE
    +1 to SR20
    Aug 2004
    Forget the SR18. If you're already spending, just go straight to the SR20DE.
    Don't forget to upgrade the rest of the car to suit the power.
    + 1 sa SR20DE.
    Wag mo kalimutan yung brakes ha.
    Sent from my 3210 using Tapatalk HD Premium
    Sep 2012
    + 1 sa SR20DE.
    Naalala ko yung barkada ko dati na mekaniko... May inayawan sya na trabaho kasi gusto lang ng may ari ilagay palit lang ng 2.0 liter EFI na makina pero ayaw magpalit ng break ... kargado konsensya daw nya pag nadisgrasya yung makulit na may ari kaya hindi nya ginawa
    sr20DE na, ihanda mo lng bulsa mo.
    SR20DE but make sure you can find proper front axels that will fit your b13 Sentra without the need to fit/weld them.
    May 2013
    mga sir.. mga how much po kya need ko prepare if i opted to SR20 including all the changes i need n baguhin sa oto.. mas mganda po pa turbo o ung DE lng.. tapos saan p po kya ako mkakabili good quality n engine.. newbie lng po kc ako in terms of car.. thanks po sa mga advise...
    Bakit ka pala magpapapalit sir?
    If newbie ka lang sa car, baka masyadong overkill yung SR20DE sayo?
    Changing the engine is no joke. Dami mong kailangan i-consider and you really need to have a deep pocket para okay lahat. Sayang lang if you cheap on parts and repairs. Baka madisgrasya ka pa.
    Jul 2011
    just like renzo said,
    kung newbie ka, hayaan mo na muna yung stock engine, kung hindi pa naman palitin yung makina, pwede na yan to start with,
    know the basics ika nga, your heading agad sa tuner's territory with inadequate knowledge, mahirap yan, baka mas mapagastos ka pa sa huli, and worst, masira mo pa yung makina mo kinabit if hindi mo pa alam gagawin.
    stick to the basics muna and do a lot of research and ipon ipon pa budget at the same time, para pag ready ka na, alam mo na more likely sa pasikot sikot na gagawin.
    goodluck sir!
    May 2013
    nasa akin n po ung car ng 1 year pero mostly erpat ko gumagamit. pangmalapitan lng.. pero one time dinala ko xa sa manila kaso ng whitesmoke xa at ngbabawas ng engine oil ng pinacheck ko xa.. need daw ioverhaul.. kaso im thinking n plitan nlng engine kesa paoverhaul kc tumawag ako sa nissan for the genuine parts mejo mlalakihan din eh...
    by the way... Sentra B13 + SR20DE = Civic SiR eater.
    Quote Originally Posted by devileyesdemon View Post
    Actually, mas malaki gagastusin mo pag nag-engine swap ka.
    It's not buy engine, put engine, drive.
    It's buy engine, put engine, fix engine, tune engine, buy other stuff that should go with the engine...
    And your sources should not be CASA. Dapat alam mo agad where to buy this and that.
    I'm not sure kung may SR20DE sa Cinco (tama ba?) Cubao. Pero should you push through with your plan, yun.
    Just please, please don't forget to upgrade your brakes. Getting into a possibly fatal accident is the last thing you'd ever want.
    May 2013
    yes sir. i was just thinking n if mgbaklas ako engine genuine ung ipapalit kya tumawag ako sa casa.. pero mga sir if i opted to buy engine anu ung mga normally n pinaplitan sa engine. and mga how much kya aabutin.. estimate lng mga bossing if pati ung need ko bghin aside from the engine will be considered.
    May 2013
    mga sir thanks pla sa mga inputs and advice.. really appreciate each and everyone inputs... :-)
    Feb 2012
    sir ano po gnagawa sa brake pag inaupgrade at anu mga pinapalitan sir?
    TIA
    Quote Originally Posted by sotel View Post
    TIA
    either bigger rotor or bigger brake caliper or both.
    Feb 2012
    kaya practical un 1.6 engine na pamalit, di man ganun kalakas un power madami available parts if ever magkaproblema saka mas matipid sa gas, sa overhaul pinaka challenge dyan un gagawa, ingat ka sa mga nagmamarunong na mekaniko, if habol mo talaga un power, straight mo na sa SR20VE, 180-190hp saka plus 1 sa nasabi nila, upgrade mo din brakes if ever
Nissan Sentra B13 wanted to change engine
