Results 51 to 60 of 62
- Jan 2008
- 4,726
August 31st, 2021 02:50 PM #51Just be careful with back feed charging.. lithium cells are voltage sensitive.. the best way to charge is by individual cells which is the task of the BMS..
unfortunately, the bms will stop charging once the set voltage have been reached even though 1 of the cells need more time to charge.
if that is the case either the BMS is defective or one cell in that pack is defective.
August 31st, 2021 03:27 PM #52
It worked!
Back-feeding the batteries for about 15-20 minutes I guess woke up the BMS. It probably needed the battery capacity to reach a certain minimum percentage. Prior to this, I only charged the batteries up to 4%.
This is the back-feeding setup.... it won't pass OSHA standards, I know.
It's now taking a charge through the charge port; the red LED is now lit on the charger (upper left)
The ESC logic is also seeing that the batteries are being charged.
Now, I'm doing a no-load, 20kph cruise control on the bench to let the batteries drop down to 40%. I want to check if anything is getting warm/hot or if an error message pops up. Then I'll charge it back again to full.
I'm happy it got sorted but I hope I wouldn't have to do this ever again.
- Jan 2008
- 4,726
September 8th, 2021 09:01 PM #54
allowed pa sa kalsada mga elec scooters?
i have a Mi 365 electric scooter collecting dust here in SG. planning to bring it pag nauwi sa November.
- Feb 2014
- 2,536
September 8th, 2021 10:47 PM #56
- Dec 2019
- 2,072
September 9th, 2021 11:03 AM #58
May 30th, 2023 12:08 PM #59
Anyone using the M365 Pro in Baguio City? Except on very steep roads, how does it fare? Usable pa ba?
I know bawal sa Session Road.
- May 2011
- 113
June 1st, 2023 10:38 PM #60
