Page 20 of 26 FirstFirst ... 10161718192021222324 ... LastLast
Results 381 to 400 of 505
    Oct 2019
    #381
    mga sir.. ask ko lang kung ano kaya pinaka ok sa mga pinagpipilian ko and bakit,
    a. Technical Details
    b. Optimum Impressions
    c. ATMT Car Care Santolan
    Thanks in advance!
    Quote Originally Posted by sowss View Post
    Thanks in advance!
    OI.. Gtechniq 5yrs warranty and the price is good. That is where most of us had our coating
    Feb 2014
    #383
    Share ko lang experience ko with Ceramic Coating from MDPro - Manila Detailing Professional.
    I opted for them because of a referral from a family member and also the cheapest among the known/reputable shops offering Ceramic Coating (7500 for 3 years and 11500 for 5 years using ChemGlaze Nano Ceramic Coating). The price is inclusive of inspection, carwash, iron removal/decontamination, Clay Detailing, Watermark Removal, Paint Correction, Exterior detailing and protection, Mag wheel detailing and coating, pre-cleaning, application of chemglaze and final inspection.
    My review:
    1. Gloss 4 out 5. The vehicle is glossy.
    2. Hydprobic properties . Have not tested yet. will update later.
    2. Prep-work etc. - 2 out of 5
    I was disappointed with the prep-work because there are still swirls marks - they only removed about 90% of the swirl marks. There are also still light scratches. They claimed that light scratches cant be removed because they are too deep or the clear coat is too thin. I don't know any better but in my opinion since the scratches can't be felt by hand and are only visible under certain angles or light, they are still considered light scratches.
    Also, I noticed that white powder residue (which must have come from the polishing) got into the crevises (windows and the gaps around the vehicle).
    But what really ticked me off is their claim and assurance that they did the mags. When i got the car, i noticed that the mags are a bit dirty, i asked if they forgot to do the mags and they assured me that they detailed and coated the mags. However, upon closer inspection, i noticed that some of the plastic cover of the mags (factory plastic) is still there. the paper sticker that was on the mags and the tire ( i think it was used by the factory to align the mags and the tire) are still there. Clearly, the mags have not been cleaned/detailed contrary to their claim.
    Disappointing. but i guess, i got my money's worth. someone can always do it cheaper. but if you want it done right, dont go for the cheapest option.
    Dec 2017
    #384
    Quote Originally Posted by black0men007 View Post
    My review:
    Thank you for your review. I've heard that Technical Details does a good job.
    Feb 2014
    #385
    I need your opinion. What i understand of ceramic coating is limited frompaper-sticker.jpg what i read on forums and blogs and what i see on you tube. But as i understand it, the basic process for mag wheels coating is - 1. Thorough wash; 2. decontamination (to remove iron and brake dust); 3. thorough wash again; and finally 4. Coating.
    My question is this: is it possible that after going through the mag coating process, is it possible that:
    1. the dust in the interior of the wheels appear untouched (see pictures below);
    2. the factory plastic in the wheels will still stick / has not been removed (see pictures);
    3. the small paper sticker - used to align the mags and rubber - will still be there (see pictures)
    Thanks for your help.
    Oct 2003
    #386
    How long was the downtime until you got your car? Kung matagal, dust could have accumulated sa wheels (benefit of the doubt). Usually the important part that they coat is the inner barrel.
    Also kung polished siya not sure kung they can coat it. Usually kasi painted areas lang pwede i-coat.
    Jul 2013
    #387
    ^ceramic coating is for the car's paint... kapag may natira, sinasama na nila yung mags.
    I was there nung nagpa-ceramic ako (5 hours) and di naman tinaggal yung mags ko para malinis ng maayos... so labas lang talaga yung may exta linis.
    Feb 2014
    #388
    Quote Originally Posted by zechs View Post
    it was there for two days. according to them, they coated the mags. i actually thought they might not have coated the mags or simply forgot (judging from the state of the mags) but according to them they did coat the mags.
    I thought that when they coated the mags they were supposed to wash and decontaminate to remove iron particles (according to youtube). If they did the decontamination and washing part, the dust and the stickers and plastic would have been removed.
    One possibility is that they did coat but did not wash or decontaminate which means that they coated over the stickers and the imperfections /watermarks.
    Feb 2014
    #389
    Did they wash and decontaminate sir? or wipe only? in my case, the stickers and plastic cover were still there. The sticker is just a simple small circle paper sticker (i think used by casa or the factory to align the mags and the tire). I was expecting that at least they would clean the mags thoroughly to remove the dirt and some minor watermarks / water stains (even if they won't decontaminate) before coating.
    For me, its worse it they coated without cleaning because the dirt will be protected by the coating.
    Jul 2013
    #390
    try washing your mags... kapag natanggal yung dirt, I guess wala syang coat.
    yung labas ng mags ko were cleaned... kaso naubos yung coating kaya di na umabopt sa mags...
    Jul 2013
    #391
    Thanks in advance!
    asking for pinaka-OK means 3 cars side by side by 3 different detail shops.
    Personally, I chose Optimum kasi may IR lamp sila, so no need to leave the car overnight.
    Jul 2013
    #392
    Oct 2003
    #393
    As one forumer said here, you should wash your rims. If it beads then they coated it. As I've said, it depends on what coating they used. Baka naman not compatible with polished rims ung coating nila. Only for the painted part. So looking at your rims, ung gloss black parts lang ung ni-coat nila; and presumably the inner barrel.
    And I dont know how the shop coats the wheels, naka-wheels off ba sila or hindi?
    How old na ung car mo? Kasi you said watermarks on the rims, were you referring to the face of the wheel or the inside?
    Gtechniq CSU
    Amazing outcome. though i prefer nsx red or ferrari red. watch in 1080p50
    Apr 2014
    #395
    Quote Originally Posted by atty.cadmus View Post
    I am convince. Di na ako magpa pa ceramic.
    Wash and wax na lang. (microtex, soft99 o turtle) hehehe
    Magpapa ceramic ako gawa nang isa lang covered carkpark lang sa bahay. Open air yung dalawa so need extra protection. [emoji16]
    Sent from my Mi MIX 3 using Tapatalk
    Dec 2019
    #396
    Hello everyone,,
    I'll try cerami coating this year. Di talaga ko mapakali sa light scratches sa likod ng door handle. Kahit bago puro scratches. Feeling ko display car sa casa yung nabigay na unit sa akin. Haha.
    Hindi na talaga ako nagagalingan sa big bert's araneta. Compared to years ago, ibang iba ang quality of work kahit car wash. Nung minsan nakapila ako sa labas ng gate and di bumaba ng car. Nakita ko kung paano magclay ng paint surface yung carwash boy. Kabilis and selected area lang. lol
    #397
    ^Copy-paste ng post ko before?? Haha
    Nov 2017
    #398
    Quote Originally Posted by Humanjo View Post
    Hello everyone,,
    I don't think ceramic coating will spare your car from swirls and light scratches. As long as your car is not properly washed/cleaned, swirls will be inevitable.
    Light scratches behind the door handle are usually caused by fingernails. Expect more of those scratches with unmindful passengers. So far I've managed to prevent these scratches by opening the doors for my passengers.
    Oct 2003
    #399
    You can polish the scratches out sa door bowl (hopefully) then after put a sticker sa door bowl to prevent scratches again.
    Oct 2007
    #400
    How often do you apply ceramic coating on your car, once a year? Once every 2 year? Or twice a year?
Ceramic coating
