Results 11 to 19 of 19
- Jan 2007
- 4,459
December 5th, 2009 02:54 PM #12Z Works
Same lang lahat yan mas okay OEM style hood nalang, unless mabilis un car mo pwede CF hood na may hood scoop
BANNER BANNER BANNER
- Jun 2008
- 1,439
December 5th, 2009 03:44 PM #13Plus one!
Otherwise, your car will end up here:
http://tsikot.yehey.com/forums/showt...69#post1376869
- Dec 2007
- 2
December 8th, 2009 08:33 PM #14http://www.zerolightech.tk/
Check out that website bro. I'm sure they have one for your car. If not, they can fabricate one for you.
December 29th, 2009 09:40 AM #15
hi...i'm from merville...may alam ka ba for bluebird and how much...thanks
- Feb 2008
- 577
December 29th, 2009 10:22 AM #16usually cf hoods sold in the philippines are just "skinned."
the underside is made of fiberglass.
real cf materials are made of straight cf with honeycomb core and vacuum infused. i doubt if any shop here makes this kind.
- Oct 2009
- 35
January 5th, 2010 03:26 AM #17
February 25th, 2010 05:37 PM #18
hi sirs, newbie question - kapag fiberglass with CF skin, lalagay ba nila CF film (gaya nang sa 3M) or CF vinyl wrap? o pareho lang sila?
pag ganito un set up, meron din ba sya heat rejection from the sun? mas hindi iinit ba un engine with this set up?
manny
February 26th, 2010 08:13 AM #19
please disregard my newbie question above, nag researched nalang ako about carbon fiber reinforced polymer (CFRP) and carbon fiber weave (tnx to this thread for giving me inspiration). also searched ebay, grabe taas pala prices nang mga CF hoods with fiberglass frame (FRP). ito mostly ang binebenta nang mga sellers/shops.
i'll just include what to look for in a CF hood:
-check the carbon fiber. higher quality means a tighter carbon weave.
-check the clearcoat... it must be tough with a high gloss, smooth surface. no bubbling and yellowing. un pinatong/painted resin should have UV inhibitors (UV coated)... will keep the CF from yellowing over time.
-common weave is plain and twill weave
high idle RPM at engine start
