Results 11 to 14 of 14
May 28th, 2014 11:35 PM #11
Magpagawa ka ng plate na may corner holes at meron din syang center holes to match your after market pedals. I-mount mo sa ilalim ng after market pedal if you got what I mean. Use the corner plate corner holes to fit it the accelerator pedal. Para di masira yung original pedal ng oto mo.
May 29th, 2014 12:05 AM #12
sir jaypee, hindi ganyan yung nabili ko. yung saken mas maliit tska yung holes wala sa corner, nasa inner part ng pedals kaya feeling ko dapat replacement siya sa rubber instead na iniipit lang.
thanks sir red_one sa pic. malaki rin yung gap between the pedals, mukhang crossover/SUV yang tsikot mo sir. ganyan din yung naka-install before, kaso problema parang less than an inch nalang yung gap ng both pedals kaya tinanggal ko.
thanks sir confuscious sa idea. sige try ko yung ganyan. no way kasi na ma-screw ko yung after market pedal for the accelerator since ang holes ay nasa inner part ng pedals.
follow-up question pala, what if tanggalin ko nang puwersahan yung rubber sa accelerator, ano magiging itsura niya? katulad ba siya sa brake na may metal plate with holes? or metal rod lang na parang skeleton ang makikita ko?
May 29th, 2014 12:43 AM #13
^Kung tatanggalin mo yung rubber, yan ang di ko alam kung ano hitsura. But ang maaring mangyari is masisira yung rubber, hindi mo na maibabalik. Molded to metal siguro yung rubber. Really don't know.
May 29th, 2014 03:34 PM #14
oks thanks sir CS. mukhang i'm inclined to your idea, siya na ang most feasible na nakikita kong solution.
thanks for helping mga sir (jodski, jaypee, red_one, CS)!
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
