Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
    Jul 2004
    i've tried doing 60+ on an almost 90 deg curve. that's the last time i'm gonna try it. muntik na akong tumaob. like what they've all said, if you want speed then an SUV is not for you.
    I have yet to roll over my rig. I can drive it with only three wheels touching the ground off-road and have traversed some pretty steep side slopes already.
    On road, I can also drive it agressively and take on sweeping curves at speed. Body roll is scary but it does not mean that a rollover is impending.
    Remember that the tires do not have enough frictional coefficient to flip a rig over on its own. Rollovers are usually caused by 'tripping' when the tires get buried in dirt or when the tires hit ('trip on') the curbside causing the vehicle to rollover.
    Btw, my rig is lifted and has off-road tires.
    at what tilt on the pajero's dash pod would it show before it actually rolls?
    most i've done shows around 30 degrees tilt when i took the circle to commonwealth road at around 80kph with suspension set to hard...and never tried it again. hehe. although afterwards when i was turning right to CP Garcia, i did induce oversteer.
    hirap talaga kung malalate sa work...on a 4am. :D
    The propensity to roll would still depend on speed. You could hold a Pajero on a 30 degree side slope all day and it will not flip.
    ayun pala...so i should've added at what speed na rin ;)
    Aug 2004
    para ma lessen yung pagtaob siguro. best solution is babaan nyo yung center of gravity. like lowering. hehehhehe!!! lowering a 4x4???? against ata sa rule un ha.peace
    yan: onga eh. hehehehehe...
Taubin daw ang pajero?
