Results 11 to 19 of 19
July 31st, 2013 11:21 AM #11
Stall engine could be EGR, SCV & Fuel filter, seems parang rhythm ang stalling mo ,Im more inclined sa SCV ang fault
- Jul 2013
- 193
July 31st, 2013 01:54 PM #12di ba may thread na kapag fail ang scv eh aandar pa din ang makina ng strada? kc ang denso scv daw eh by default open sya? have you tried opening the intake manifold? useless ang cleaning lang ng egr since ang linilinisan ang doon ay yung egr pipe. hindi naman nadudumihan yung egr, ung pipe lang nman.. better blank your egr kapag na diagnose na strada mo sir..
July 31st, 2013 02:27 PM #13
Im not sure if it is acceptable to blank the EGR, kasi on the long run it will damage other ancillary parts, the other day I just changed my EGR thru Diamond service center. Cost around P8K excluding labor, dati dati linis linis lang, it reach the point na kailangan palitan na. Out of curiousity binuksan ko yung defective daw, it consist springs, valves & gears that push the valve to open,nilinis ko then lubricate ,palagay ko pwede na uli, sana there's means of testing if it is working, same as the inhibitor switch ng transmission, consisting of three points contact, cleaned it with contact cleaner palagay ko okey na.
Thats the problem with casa they are easy to replace the whole unit, they wont dare to pry open , I will just keep it as reserve ,at least it give me the chance to answer ano ang nasa loob na ito at takot buksan ng mga service center ng casa.
July 31st, 2013 02:35 PM #14
- Jul 2013
- 193
July 31st, 2013 03:58 PM #15paano po kaya nasisira ang egr motor? eh d ba wala naman xa carbon build up? sa pipe lang naman.. ganun ba kabilis masira ang egr? mine is 75kplus on the clock di pa naman sira egr.. been balnked it after cleaning the manifold till now ok pa naman sya.. egr in some countries are required for car manufacturers for emission.. olser diesels dont have it. walng nabago sa engine except or the pipes and sensors. dapat ibalik pa rin sa casa yan kasi sila ang expert kuno jan jeje! d naman po kaya limp mode na yan?
- Jul 2013
- 193
July 31st, 2013 04:01 PM #16
July 31st, 2013 05:02 PM #17
- Jul 2013
- 193
July 31st, 2013 05:26 PM #18ah ok sir hehe.. sir where's the inhibitors switch ng trnsmission located?
July 31st, 2013 06:39 PM #19
^All branches of Jiga Primacy and XM2 lang available :( Is Roadstar good? I want Michelin brand...
Finding the Best Tire for You
