Results 1 to 10 of 19
- Jul 2013
- 2
July 26th, 2013 05:46 AM #1What could probably be wrong with my strada? Namamatay na lang tapos umaandar ulit. Nagpalit na ako ng fuel filter, linins na ng tank pero ganun pa rin. Manual na bomba ng pump tapos andar ulit. Sandali lang tapos patay ulit. 200km away ang service center. Help!
July 26th, 2013 12:18 PM #2
Check the water separator. Might be some residual water in the tank.
- Jul 2011
- 1,711
July 26th, 2013 12:32 PM #3sir na subukan nyo na po ba e-bleed ung fuel line, baka lang po meron nahahalo na hangin
- Jan 2008
- 4,726
July 26th, 2013 12:32 PM #4DiD na ba yan or yung luma pa na strada?? baka may hangin or singaw along the fuel lines kaya pag binomba mo yung pump eh nalalamanan yung injection pump tapos mauubos ulit
- Jul 2013
- 2
July 26th, 2013 12:38 PM #5Nagpalit na po ako ng buong filter assembly. Naglinis na ng egr pero ganun pa din. The strada is 2007 model. Nacheck na din fuel line pero wala naman daw leak. After cleaning the egr umandar naman ng mga 10 minutes tapos namatay ulit. No parts replaced. Just cleaned them. Except for the pit pump assembly na pinalitan ng bago
July 26th, 2013 01:37 PM #6
I think your a EGR is the culprit. Nangyari na rin saken yan, pinalinisan ko na din EGR peri ganun pa rin. Ayun pinapalitan ko and pinareset ko, SIQL ata tawag nila dun.
#Retzing
- Jul 2011
- 584
July 26th, 2013 01:50 PM #7pag mali ginamit ng panglinis ng EGR nadadamay yung position sensor,
parang nadadamay yung carbon. kaya pag carb cleaner nasisira ito.
At minsan lang daw pede linisan yung EGR tapos replacement, Accdg to Denso service center (dito di ako naniniwala).
kung masyado na madumi EGR mo, malamang pati intake mo madumi na din at restricted na pero dapat tatakbo pa din ito wag ;ang barado talaga.
July 26th, 2013 07:25 PM #8
Saan ba probinsya mo? Baka may ibang casa dyan ng ibang brand na pwedeng i diagnose yang strada mo.
CRDI naba ang 2007 model? Nasubukan mong gamitan ng diesel purge (fuel line cleaner)?
- Apr 2010
- 131
July 26th, 2013 07:33 PM #9My CEL ba?
Kung meron better check the code para mas madali diagnostics.
Very possible SCV, I think.
hth
July 26th, 2013 10:13 PM #10
strainer sa fuel tank baka barado
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
