Results 11 to 19 of 19
November 20th, 2002 09:54 AM #11
Shift on the move nga ang Strada pero you can't use it in 4WD mode on paved roads dahil wala siyang center differential. It will 'bind' on tight corners. It will shift into 4wd with no problems pero when you turn parang ang lakas ng understeer or sometimes it will simply refuse to turn.
- 10,620
November 20th, 2002 10:15 AM #124x4fan,
yun hi-lux, underpowered, masikip sa loob, sobrang tagtag, pero ok siya sa aftermarket parts lalo sa mga off roaders
yung GEN2 strada, pang all around, ganda pa ng suspension
so kung pang weekday workhorse mo i suggest you buy thr strada automatic transmission,
yan din ang sagot ko kung papipilian mo ako
crank mo na lang torsion and palit shackles tapos 32 inchers na A/T tires
ayos na!
- 342
November 20th, 2002 10:49 PM #13kimpoy,
yan din ang naisip ko, parang ok ang strada daming features yun bago, meron pa syang euro 1 compliant ok ba ito?
Otep,
so yun strada di pwedeng i shift sa 4wd sa pavement sa offroad lang , paano kung madulas sa hi way pede b i shift kung straight lang ang takbo?
pajero kid,
Thanks sa advise re the land meter. pero wala bang bago nito?
November 21st, 2002 12:22 PM #14
Euro 1 compliant means cleaner exhaust. Sabi ng sales agent mas konti daw black smoke.
On shifting to 4WD on paved roads, yes you can shift on the pavement pero their is a braking effect when you turn the wheel. Kung madulas ang daan at medyo madulas driving in 4WD may help better control by adding traction. Pero when shifting kailangan in a straight line.
On land meters, may bago pero taga sigurado ang presyo mula sa Casa.
Goodluck.
Tsikot Member Rank 5
- 3,144
November 22nd, 2002 12:26 AM #16
OT:
4x4fan::: hi. if youre referring to the landmeter of the delica, i dont think you can get it bnew here, unless mag-special order ka from casa (tagal and hindi guaranteed na makakarating).
- Feb 2007
- 21
November 14th, 2009 09:33 AM #17question lng po. ung bang mga strada nyo gen2 4d56tdic gang san nyo napapapalo ung rpm nyo? ung sakin kasi parang pondo na cya 3k-3.5k lng eh.beyond that parang ayaw na bumatak.
November 14th, 2009 09:43 AM #18
- Feb 2007
- 21
Having problems posting images as well.
Problems with viewing Tsikot on non-Chromium...
