I noticed after my long trip back from the province, upon starting it in the morning malakas yun vibration ng engine and then tapakn mo gas mamamatay. After a few starts like this normal na sya. And during the whole day ok na sya. During 1st few starts in the morning. Nagstart lang talaga ito after my long trip back and forth to the province.
What could be the problem, dinala ko na to my 2 suking talyer, wala daw sila mkitang problema. Hindi raw mababa idling, oil/air filters were changed 2 months ago. Pinacheck ko rin engine support pero ok din daw. Sabi ng isa injection problem daw??? Pero I doubt it...
What could possibly be the problem. By the way 38th palang takbo ng ride ko. Thanks.....
usually pag may air ang fuel lines may misfiring feel like sa mga gas engines, especially on idle, but hardly felt on high rpm. the air will disappear after the car has run, unless my leak ang fuel lines then there will be air pockets in the fuel and misfiring or palyado feel can sometimes be experienced.
what should be the idling behavior upon first start ng 4m40 sa umaga, will it start on a high rpm then gradually go lower as it heats up?
i never really noticed until kanina, nagpa 30k check-up ako kahapon and i noticed this morning na kabaligtaran ang nangyari. nagstart sya at low rpm like around 6000 to 6500 then umangat after awhile.
I have the same problem with my Gen 2.5. When I start in the morning normal for a few seconds then mag drop ang idling so I have to rev the engine ng mga 1500 to 2000 till mag init. Pagnamatayan ka bago maginit, mahirapan ka na mag start. My glow plugs are only a few weeks old and I already installed a manual switch to turn off the plugs after starting. According to a mechanic of mitsubishi, the reason nasisira ang plugs agad because matagal mag auto off. Im using a switch with light so I know if the plugs are on or off. To make it start without misfiring, I have to turn on the plugs then I have to wait for the plugs to turn off ( switch light ) before I start the engine. Medyo nakakaasar dumadami ang seremonya every morning lalo na kung iba ang gagamit ng kotse. Namamatayan sila.
that's bad news sa ating mga naka 4m40 engine. sa umaga ang problem. why not try using thinner oil like 5w-30, and diesel booster from petron. 44 pesos lang naman isa, every full tank. bboth can help sa cold starts, yan ang gamit ko. I know di siya solution, pero malay mo mapadali ang warm up ng engine.
