Results 1 to 5 of 5
- Nov 2006
- 8
November 10th, 2006 12:58 PM #1Can anyone help me find a mitsi 4G63 Turbo motor with or w/o ECU. Tranny is not required coz this will be for a box type transplant project. Please provide contact info.
Thanks.
November 10th, 2006 04:32 PM #2
Don't have contact info, but you can look around at the shops in Evangelista, Makati. This street can be reached by turning right between Jollibee and McDo on EDSA southbound after the Magallanes flyover. I used to buy engines from Dom at a place called "Parts n Shop" (at least, I think it's called that).
How are you going to do the transmission? Machine shop an adaptor?
- Sep 2006
- 110
November 10th, 2006 06:54 PM #3there's a place in marikina that imports japan parts, engines etc. thats where we get parts for our vw,
- Nov 2006
- 8
November 10th, 2006 09:31 PM #4thanks for the replies but would you guys happen to have the shop's phone number?
Niky, concerning the tranny I did some extensive research and found out that mitsubishi only have two types of RWD belhousings (small / narrow and big / wide). Small bell housings are used by 4g3X's and can be adapted for 4G63's. Though 4G64's utilized a wide bolt pattern and it can only use a big bell housing. RWD big bell housings mostly came from Starion or Conquest with a 2.6L engine US version. Japan version Starion's had 2.0L.
November 11th, 2006 01:39 PM #5
Try mo sa Initial D. Baka meron silang 4g63.Parang meron na akong nakita na nakakabit na ganyan sa macapagal ah.Ang bilis nga eh kaso biglang natanggal ang gulong niya sayang.
high idle RPM at engine start
