Results 11 to 12 of 12
July 26th, 2010 06:34 AM #11
Iyong sa akin ganyan din problema lagi akong naglalagay ng tubig sa umaga nagbabawas ng tubig may tagas na kasi iyong water pump kailangan ng palitan.
- Aug 2005
- 553
August 11th, 2010 01:41 PM #12Your engine's cooling loops should be a sealed system. You should have enough coolant for 100,000 km even when you factor in evaporation and permeation.
Suffice to say, may tagas yung makina mo. Likely there's a crawling leak hence why you can't see it. But emptying it within 2 hours should be pretty obvious.
And don't leave it with just water, you're just begging for corrosion.
high idle RPM at engine start
