Results 21 to 30 of 31
- 400
February 4th, 2003 07:20 PM #21diba yung GEN2 pajero ok lang kahit laging naka 4H? yung GEN1 di pwede?
February 4th, 2003 09:03 PM #22
if you have Gen 1 you can use your 4L going up. since your car is eqipped with manual locking hubs and if you dont lock it only the rear tires will have traction so there wont be binding on your drivetrain. power will be transmitted to the front diffs but they will not be transmitted to the front wheels since the hubs are unlocked.
February 4th, 2003 11:41 PM #23
splerdu,
Walang center differential ang GEN I (direct drive/conventional).
Yung saken umaakyat ng Baguio in 2nd gear.
- Nov 2002
- 70
February 5th, 2003 01:45 AM #24Kailangan mo ng remote start para pag sakay mo ng sasakyan warmed up na yung engine mo. :lol:
RIDE ON...
FrankDrebin Guest
- 238
February 5th, 2003 03:43 PM #27Ok - follow the suggestions of warming up the engine properly (especially if you are going to charge up the driveway), having your clutch checked - it could be sliding, or checking your driving style - is your foot still on the clutch even when the vehicle is in gear?
If everything checks, then you can use 4H. Its just for a short duration and practically a straight line up right? However you will have to get off the vehicle to engage your hubs (lock/ 4x4) before you ascend and get off one more time to disengage (free/4x2).
Best thing to do is to keep the hubs free (4x2), shift to 4L and drive up on 1st / 2nd. No momentum will be required as you are employing your vehicle's lowest gear, and (as a benefit) not stressing your engine. Essentially you are on 2L (2 wheel drive Low), because the front wheel/axles are disengaged.
Try it and enjoy.
- Feb 2003
- 618
March 4th, 2003 05:02 PM #28ndi pwede yon, as much as possible sa first gear ka lang, wag second gear and... kumuha ka ng bwelo, and pag aakyat ka na kailanan tangal ang paa sa clutch , kun ndi titirik ang makina.:mrgreen:8O
March 4th, 2003 06:55 PM #29
mk:: hindi titirik agad ang makina pag naka low range... kahit wag mo apakan ang silinyador.... bilibid or not :mrgreen:
March 5th, 2003 12:14 PM #30
try to heat up the engine muna para d mabigla..
mahirap umakyat from a cold start..
when im in baguio..
bago ako lumabas..
pinapainit ko muna yung sasakyan bago ko isabak sa akyatan..
mabagal po talga mag-respond yung sasakyan
kapag hindi pa nag-heat up ung engine..
my two cents..
(starex TDI po yung ride ko..same engine ng Paj..
ganun din po yung ginawa ko nung minsang dala ko yung Paj ng Dad ko.)
Just had a chat with a friend in upper management of Nissan Phil. They are releasing two new...
2025 Nissan Kicks
