Results 11 to 17 of 17
January 25th, 2004 02:25 AM #11
Pinagawa ko lang sa shop ni GlennSter sa Kamias. Php 80.00 is the labor cost alone. Siyempre iba ang cost nung part (can't remember na).
Binaba kasi yung intercooler ko kaya siguro naging Php 80.00. hehehehe. Baka mas mura yun kung madudukot na agad.
January 26th, 2004 12:32 AM #12
tnx po sir otep.. lapit lang pala samin kela sir glenster.. hehe.. kamyas lang pala
- Nov 2004
- 115
June 13th, 2005 03:27 PM #14i tried replacing fuel filter kahapon sa 4D56.. grabe ang tigas! nagkasugat sugat nako.. di ko padin natanggal.. i removed the interncooler din to give space.. i realize na kelangan kong bumili ng oil filter remover ba yun? kasi ung tali na gamit ko kahapon.. suko nadin sakin..
anyways, tama ba ang gagawin kong step?
a. remove the hose
b. remove fuel filter
c. remove sensor
and kapag naibalik ko na.. anong proper way para i-bleed un?
thanks!
- Jun 2005
- 73
July 29th, 2005 03:16 AM #15yung sa L300 namin, after ko ma-assemble at ma-loosen yung bleed screw at filter plug sa ilalim, bakit nung pina-pump ko ng maraming beses na, wala pa ring lumalabas na fuel doon?
kaya ginawa ko, hinigpitan ko na yung bleed screw at filter plug sa ilalim at inistart ko na lang, umaandar naman, tapos mga ilang minutes, parang nanginig then um-ok na ulit. ok na kaya yon?
- Nov 2004
- 115
August 8th, 2005 04:58 PM #16sa wakas, napalitan ko nadin fuel filter.. medyo madugo din pala ito.. but i've learned my lesson well..
i have to remove the entire hand pump sa sobrang tigas ng fuel filter.. with the right tools hindi siguro mahihirapan..
June 10th, 2011 04:07 PM #17
It's best to 1.) remove first the fuel lines then 2.) remove the whole mounting then 3.) remove the sending unit tapos 4.) oil filter wrench na bahala sa pagtanggal ng fuel filter sa mounting.
high idle RPM at engine start
