Results 11 to 18 of 18
August 28th, 2004 03:22 PM #11
Some ex-JDM units have speakers in the doors and dash depending on grade and trim level (base, GLX, GLS, Exceed, etc.).
On my local unit, the dash speakers were 4" coax units.
The cargo compartment can accomodate a 6" x 9" speaker. But Mitsubishi just put in a lousy 5.25 on mine.
August 28th, 2004 03:40 PM #12
Thank you sir OTEP, it;s an Exceed, and i found out that there is a 10cm on the dash (below the ac vent), 13cm on the front doors and 16cm on cargo compartment, youre right 6"x9" can be fitted.
- Feb 2004
- 136
August 30th, 2004 12:58 PM #13i've fitted a 3way system sa stock locations... 6.5 sa sidings, 4" sa mounting locations below the side a/c vents and tweeters sa stock pods on the opposite side ng side mirrors. pwede kung sa pwede, kaso ang downside lang is poor imaging due to the firing angle of the midrange.
- Feb 2004
- 136
August 30th, 2004 12:59 PM #14i've fitted a 3way system sa stock locations... 6.5 sa sidings, 4" sa mounting locations below the side a/c vents and tweeters sa stock pods on the opposite side ng side mirrors. pwede kung sa pwede, kaso ang downside lang is poor imaging due to the firing angle of the midrange.
August 30th, 2004 01:01 PM #15
PICTURES!
*my apologies to bretwalda of 4x4wire.com
- Feb 2004
- 136
August 30th, 2004 01:01 PM #16baka nga pala meron dyan na hindi na kailangan yung takip sa loob opposite ng mounting ng side mirror, yung triangle na plastic, either ibenta or baka pwede ipamana niyo na lang sa akin hehe.
August 30th, 2004 01:10 PM #17
I did the same thing Pajheroy, isa yan sa pinagkaabalahan ko diyan..Thanks sir otep sa pictures.
high idle RPM at engine start
